Good evening/morning gentleman!
Unexpectedly, I collected the radiators with following dimensions in mm: 320x7.5 cm fins - 3cm. to-3 pre-drilled (four per side). I know that these are not massive, but some 30W would spread to my mind. Therefore, it is thought to build one more monster but with MJ 15003 / 4 outputs or maybe JLH 10W. Is there some similar circuits which allows to put in parallel outputs, because i don't want these empty holes/fake transistors instead of working ones.... I could also use the MOSFETs in some variations Pass ZEN or similar, if find in to-3. I don't need big powerful amp, just some 10-20W may be class A or partly class A with 12-20V PSU. What do you recommend? ![]() thank you. |
#2 |
A high quality low power amp using two pairs of 2SJ50/2SK135 Lateral Fets
for each channel. With about 400 mA total bias with a +-20V power supply, class A is sustained in a wider power range that with bipolar siblings, along with a distorsion spectrum monotonicaly deacreasing, but the exact shape is defined by the topology, though.. |
#3 |
We should look for amplifiers that can use these:
2N3055, MJ2955 MJ15003, MJ15004 MJ15024, MJ15025 Any amplifier can usually use replacement transistors in output. Sometimes even without modification. With modification there are plenty amplifiers that can use MJ15003/MJ15004. Even if they were designed with other plastic devices. This is one. Uses 2 pieces of 2N3055. TO3. But in Class A, so you need a larger heatsink, when bias hard. Death of Zen - A new Class-A power amp
lineup |
#4 |
tnx. i also like musical fidelity A1 circuit, ok ill try to simulate it with LT spice.
| Can some one suggest me an amp please | Boscoe | Chip Amps | 4 | 14th March 2010 06:16 PM |
| Suggest me a plate amp that... | Telstar | Subwoofers | 6 | 23rd March 2009 11:34 AM |
| SE amp: Please suggest a better operating point | zobsky | Tubes / Valves | 34 | 21st September 2008 12:00 AM |
| Can someone suggest a small enclosure sub? | jimluu | Subwoofers | 12 | 24th January 2008 08:58 PM |
| Page generated in 0.08696 seconds (71.86% PHP - 28.14% MySQL) with 11 queries |
