I dont know,if this problem here presented is meaned seriously or only like "brain exercise".In every times amplifier buildt with "nonideal" device will have "nonideal" parameters:high output impedance,high distortion,low slew rate(narrow frequency response),poor temperature stability etc. Nonideal parameters will lead to the nonideal sound:bass like "throwing of the ***** to the tent(ladyes and moderator certainly execuse me,but this word is mostly accurate),nonconvincing middles and "tail of distortion" on trebles. In our country we have one proverb:"You cannot do the ball by the fart" and I am sorry, but all this "dreamly project" is very similar to this proverb. I know whatabout I am talking-amplifiers are my hobby and I am buing it many years. Pavel(Paul)
#2 |
On Hiatus
I prefer 1 amplifying transistor,
if possible Single End, SE if I can get it to work properly and cope with loads. If not, I add another transistor, to co-operate in best possible way with the first. halojoy has more than 1 transistor in most of his constructions
#3 |
I also prefer fewer transistors. One is correct.
#4 |
According to Einstein "Everything should be as simple as possible, but no simpler". Too simple is as bad or worse than too complicated, YMMV. rgds, sreten. Good simple 2 transistor circuits tend to slaughter any single device option.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow Last edited by sreten; 11th April 2012 at 09:08 PM. |
#5 | |
I thought about it once, but then thought again. |
#6 | |
All the trouble I've ever been in started out as fun......
#7 |
Use the right number of transistors, if you know how to. If not, either buy something which has been designed by someone who does know how to, or use valves!
PS it is unlikely that one or two is the right number of transistors, unless you like listening to lots of low order distortion and you have high efficiency speakers in a small room. |
#8 |
Agreed. Knowing what transistors are suited to which task is important.
I have been experimenting with common mode FB loops biasing a complementary trans-impedance VAS driving a constant impedance with some excellent results. It requires a few more than two transistors to acomplish this tho....
#9 |
#10 |
With ideal components would be enough 3 transistors for perfection.
but theory is a simplified model of reality and reality is much more complex. for comparison if you want to fly you need an airplane. If you want to go to moon you need a complex spaceship. If you want a good amp you must use appropriate solutions. Also spice is a simplified model of reality Sometimes an amplifier that seems to work perfectly in numeric mode in reality is just an oscillator
| old RCA transistors- what are they? | needtubes | Parts | 13 | 23rd July 2012 09:43 PM |
| what transistors to use? | prorms | Solid State | 1 | 20th November 2006 05:14 PM |
| Best transistors | YUTK | Solid State | 1 | 20th May 2005 04:16 PM |
| transistors | Dj BASS AMP | Solid State | 1 | 31st March 2003 04:46 PM |
| transistors | lemondog | Swap Meet | 5 | 1st March 2002 07:05 PM |
