Hello!
I'm designing a system with end result 30-80dBm sound. I will need to either design or source an amplifier for the recorded sound source and buy a speaker. A little google turned up that 70dBm is the sound of piano practice and 80 the loudness of lawnmower. Then I used an online calculator and found out that 70dB is 1000kW. 1. How does this 1000kW relate to the speaker that I choose? 2. If my sound source is a memory chip on an embedded systems board, how do I get the sound to this level. 3. Sound source is something I will record and is similar to drum beat. Any suggestions on how to get it to speaker are welcome. I'm looking for generalities....not necessarily amplifier designs! Thanks! Nora |
#2 |
A typical HiFi speaker had a sensitivity of 85 dB/W @ 1M a 2W amplifier would give a about 90 dB at the onset of clipping with an 85 dB/W @ 1 M speaker. For an embedded system, the power supply would be the main factor in choosing an amplifier.
More sensitive speakers would need less power. |
#3 | |
What's the www of the online calculator you used ?
#4 |
Have a read at post #52 here,
MJR-7 Mosfet Amplifier of M. Renardson Edit... and also, So how much power do you really need for domestic listening ?
------------------------------------------------------- A simulation free zone. Design it, build it, test it. Last edited by Mooly; 25th April 2011 at 11:32 AM. |
#5 |
Here is one of the calculators
Online Decibel Watts Calculator I type in 70 and get 10,000,000 Watts ... what am I doing wrong? Thanks!: |
#6 | |
#7 |
OK Thanks.
I like post #52, thanks Mooly, for figuring out the power needed. Seems like a 1 Watt speaker should give me what I need. N |
| Power Supply Help Needed | RickD | Power Supplies | 4 | 26th October 2010 10:23 AM |
| Power cap .........needed ??? | onis_uk | Class D | 2 | 6th April 2010 11:40 PM |
| Some help needed with a power amp | hyvärinen | Solid State | 11 | 12th November 2006 09:28 AM |
| More power needed! | stubs | Solid State | 7 | 12th September 2006 08:37 AM |
| power suply help needed !!!!!!! | mircea | Chip Amps | 0 | 28th June 2004 03:33 PM |
| Page generated in 0.09595 seconds (75.81% PHP - 24.19% MySQL) with 10 queries |
