What the heck kind of equipment are you guys using to test this stuff out?
Can you guys give us a quick rundown on how you go about testing your new designs and what equipment you use? Thanks! |
#2 |
An oscilloscope and a signal source are the bare minimum i think. Oh and a multimeter naturally. More than one is handy.
#3 | |
But then? I would like to know how people here get to measure about let's say distorsion , THD, TIM, Pass Band(i.e Gain), Phase. |
#4 |
Yea I'm wondering how you guys pump out these awesome FFT graphs and get the measurements effebi mentioned.
I have a 1MHz signal generator, Fluke DMM as well as several chinese DMM's and some analog meters. I also have a 100MHz analog scope and a 50MHz DSO. I know a few members use some pro DAC units to produce their test frequencies like the DAC1 PRE and I presume they have some equally pricy ADC equipment. Is their software that you use to measure your setup with a patch cord then measure your test subject and it will give you the response of just the unit under test? |
#5 |
Also think a variac is a must too
Steve |
#6 |
My suggestions:-
Bench power supply. At least a couple of DMMs (you can never have too many DMMs) Analogue oscilloscope. Low distortion signal generator. (Two will be required for IMD measurements) Distortion and/or wave analyser. (I've got both) |
#7 | |
I think many quote distortion measurements and so on direct from running simulations of the design rather than actual real world measurements on the finally constructed article. The equipment to measure distortion and so on down to 0.00xxx levels etc doesn't come cheap... and using PC USB "add ons" just doesn't cut it
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#8 | |
That is it? |
#9 |
better soundcards with 24/192 ADC easily reach 0.001% THD and IMD and the Nyquist frequency of 96 KHz fits well with traditional "audio analyziers" 80 KHz THD measurement bandwidth
with indirect IMD techniques you can push nonlinear distortion resolution down to the spot noise floor - often as good as -130 dB with 1 second averaging check RMAA loopback on ESI Juli@ or ASUS Xonar Essence STX the "accuracy" of 'scope measurements can't compare - but the 'scope and signal generator are required for looking for stability, HF performance issues Last edited by jcx; 25th April 2011 at 03:35 PM. |
#10 |
That's it basically. You want a constant voltage undistorted signal going into the amp. You can use 1/2-octave steps or whatever, but of course the more measurements the more accurate the plot. You don't need a scope necessarily for gain and FR; an AC voltmeter with its own proper freq response can be used.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
| test equipment | speedie | Multi-Way | 3 | 15th September 2009 05:33 PM |
| Test Equipment | jwatts | Swap Meet | 1 | 18th November 2008 02:46 AM |
| Loudspeaker Test Equipment | slhijb | Multi-Way | 1 | 2nd November 2006 12:21 PM |
| Old test equipment f.s. | Cobra2 | Swap Meet | 0 | 4th March 2004 06:15 PM |
| What's this test equipment for?? | hugobross | Solid State | 7 | 15th November 2002 03:54 PM |
| Page generated in 0.10379 seconds (78.28% PHP - 21.72% MySQL) with 11 queries |
