I have a Parasound HCA2200 Mk II amplifier (2x385W @ 4 ohm).
Very nice amp that works as it should – apart from one (a bit annoying) problem when switching it on. The left channel gives no sound before I turn the volume up quite high. Then – when the channel has been “pushed into working” by this burst of signal, it works correctly, and I can adjust the volume up and down just as I want. The other channel works normally. As far as I can see, this has nothing to do with the startup delay circuits (softstart and mute), which seem to work correctly in both channels: the relays for both channels clicking in in the same sequence and within the same time. Any clues of what can be the cause for this? All help appreciated. Regards, Espen Last edited by EspenE; 24th April 2011 at 03:41 PM. |
#2 |
I would call Tony@Parasound.com and get his opinion.
#3 |
Wow, thanks.
I'll try that. Regards, Espen |
#4 |
#5 |
I'm looking for one of these amps and am also interested in the outcome as I may have to deal with the same issue when I buy one.
#6 |
This is causes by dirty contacts of the output relay.
| Parasound HCA-800-II schematic anyone? | taj | Solid State | 3 | 9th March 2012 03:51 PM |
| Parasound HCA-2200 II Fuses | movinginstereo | Solid State | 0 | 3rd December 2009 03:31 AM |
| Parasound HCA-2200 II repair question | cocolino | Solid State | 10 | 6th September 2008 07:45 AM |
| Parasound HCA 1000A - convert from 110 to 220\240 volts? | buncker | Solid State | 0 | 27th August 2008 08:58 AM |
| Need Schematic for Parasound HCA 2200 II | mjctech | Solid State | 2 | 15th September 2005 04:25 PM |
| Page generated in 0.08815 seconds (70.53% PHP - 29.47% MySQL) with 10 queries |
