Old 23rd April 2011, 08:55 PM   #1
Bigun is offline Bigun  Canada
Bigun's Avatar
Default Crystal Sound = SRPP ?
Some interesting claims to great sound, but it looks like a kind of SRPP to me. What say you ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 23rd April 2011, 10:31 PM   #2
Miles Prower's Avatar
Definitely not an SRPP. It's an emitter follower with a CCS in the tail.
Crystal Sound System (CCStm) is the name of a new and patented Class A transistor amplifier circuit that combines the high linearity and accuarte sound of Class A with the high efficiency of Class AB. Yada, yada, yada
As if I haven't seen that before.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 23rd April 2011, 10:48 PM   #3
AKSA is offline AKSA  Australia
Gareth,
I'm never quite sure why people are permitted to patent the bleeding obvious.
Distortion of an EF is inversely proportional to the impedance in the load. This circuit still not specify a load; performance will depend on that load as much as the fancy CCS.
The signal circuit is bread and dripping; only the CCS shows signs of originality. Nelson Pass has used something like this CCS in his SE circuits, but it offers, IMHO, no substantial advantage over the usual, conventional CCS.
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 23rd April 2011, 11:24 PM   #4
I agree! jer
Old 24th April 2011, 12:02 AM   #5
The one and only
Nelson Pass's Avatar
Actually not. It is, however, a variation on things which I
have seen and/or played with. It's simple enough, and it
can maintain a technical Class A bias in that prevents
shutoff of the output devices, if not the diode.
You can also place diodes in parallel with the emitter
resistors of a push-pull complementary follower output stage
like Barney Oliver did.
Old 24th April 2011, 08:30 AM   #6
You don't miss much, Nelson......
Greetings across the years and two continents....
Hugh
www.aksaonline.com
Old 24th April 2011, 06:57 PM   #7
Bigun's Avatar
wow, my question attracted a couple of audio icon's to see what the fuss was about. It's a shame it didn't turn out to be of more value then, I can see this 'invention' isn't making anybody's short list !
Looks like SRPP ? Bigun Solid State 3 31st May 2010 10:25 PM
What crystal is this?? calvinhpk Digital Source 4 24th August 2009 03:08 PM
What crystal is these? calvinhpk Parts 6 24th August 2009 07:35 AM
To SRPP or not? duderduderini Tubes / Valves 2 12th March 2007 03:01 PM
SRPP is....? peranders Tubes / Valves 8 19th December 2003 08:38 PM
Page generated in 0.09424 seconds (76.94% PHP - 23.06% MySQL) with 11 queries
