Hi all
I was looking at the low noise designs of Samuel Gromer. He uses a 2SC3329 and compliment on one of them. What do people do now for low noise transistors as the 2SC3329, 2SC2547 etc are either obsolete or impossible to get? Rob |
#2 |
Little Diode of New Malden, Surrey claim to have them in stock so, like all our dwindling through-hole parts, get a quantity while you can. Tomorrow may be too late.
Depending on the voltages and location , 2SC1815/2SA1805 or the the old faithful 2SC2240/2SA970 are good and can can still be selected for lowest noise if that is your aim.
regards |
#3 |
Should be 2SC1815/2SA1015
lineup |
#4 |
Thank you for your responses and just a quick correction...it is Samuel Groner.
Sorry Sam Rob |
#5 |
I use often 2N5551/5401.
Not the lowest noise perhaps. But robust and good quality and takes high voltage and current. Besides I use 2SC2240/SA970. Takes high voltage. Low noise and precision. Also BC550C/560C I use. BC550C/560C are handicapped of take max 45 Volt = 2x22.5V 2SC1815/2SA1015 are good gain, low noise and think can take some voltage. Samuel Groner: SG-Acoustics · Samuel Groner · Discrete OpAmps
lineup |
#6 |
Here I have used BC550C
in a transistor line preamp with gain x10 and no global feedback. Is fed by a discrete lowdrop regulator at 24.0 Volt. Shows that we can get low THD (0.003% at 1Volt) using no global feedback. The x10 is acheived by use of two gain stages. The output is buffered into a load of 10k
lineup |
#7 |
Hi
THAT 300 series matched arrays have en=0.8nV/SQRT(Hz) @ 10Vce, 1mA, 1KHz. Ft at that quiescence is 350MHz.
All the trouble I've ever been in started out as fun...... |
#8 |
I get lots of 2SC1815s & 2SA1015s from old junk radios & stereos from the trash at a local repair shop. I have found a goldmine of parts from this heap of junk. Couldn't live without it. heh!
Where there is smoke....there is fire. (usually one of my circuits) |
#9 |
Unfortunately there are (as far as I know) no easily sourced complementary parts which show, at the same time:
* low rbb' (gives low voltage noise) * high hFE (gives low current noise) * low excess noise (gives low low-frequency current and voltage noise) * matching hFE for complementary pairs (gives low input bias current) To give a specific recommendation you'll need to elaborate on your specific application. What's the source impedance, what input bias current is acceptable, is low-frequency noise a major concern? Samuel |
#10 |
thanks for your input.
I am finding it extremely hard to get low noise complementary trannies. What are we to do in the future with many of our great LN transistors being discontinued? Sam I like you zero feedback line preamp regards Rob |
| Low noise transistor and noise figure | Real_Macgyver | Solid State | 26 | 31st January 2011 01:34 PM |
| Low noise, low microphony, low hum valves | MarcelvdG | Tubes / Valves | 28 | 31st December 2010 09:41 AM |
| preamp supply LOW power LOW noise LOW cost | drdagor | Power Supplies | 1 | 13th September 2010 11:39 PM |
| Best low-noise low-distortion buffer? | borges | Solid State | 7 | 9th December 2003 12:40 PM |
| New low noise opamp | jackinnj | Solid State | 0 | 27th August 2002 06:51 PM |
| Page generated in 0.10391 seconds (77.71% PHP - 22.29% MySQL) with 11 queries |
