Old 21st April 2011, 07:37 PM   #1
Pacorl is offline Pacorl  Spain
Pacorl's Avatar
Default Grundig V35. Hum in left channel
I was given an old Grundig V35. I was thinking in using it as a source of parts for a project like Destroyer´s "Blame Es" or similar.
When connected to a decent pair of speakers , it sounds VERY well except for a small amount of hum in the left channel. The intensity of the hum is constant regardless of the volume.I think it´s worth trying to fix it prior to start dismantling...
I have ruled out the PS as source of the hum.
Sound quality seems the same in both channels in spite of the hum. Can be ruled out a failure in drivers?
I was thinking to start checking coupling caps in the signal path as a next stage.
Any other clue?
Thanks in advance.
Old 21st April 2011, 09:21 PM   #2
smartx21's Avatar
Send a message via MSN to smartx21 Send a message via Skype™ to smartx21
At first glance, it is not worth dismantling this amp to build the Blame ES. I can't see you reusing many parts, especially for those outputs being Darlingtons.
By the other side, I've had some headache with grounding techniques. It was all right before I decided to connect my Blame ST to real ground. Noise appears when the laptop PSU is connected to the same ground point; when the electronic shower is powered on; and some other situations.
So, if not a failing electrolytic, look for grounding problems (a bad solder, lose contacts, etc.).
Max.
We should not dwell on what we do not have, but, instead, be grateful for what we do have!
Old 22nd April 2011, 09:14 AM   #3
Pacorl's Avatar
Carlos,
thank you for your feedback.
You´re right, no part from amplifier section can be reused for Dx Blame. However PSU, speaker protection section, volume control and heatsink are in excellent shape.
enclosure is not to big. The main issue would be to fit DX PCB´s inside.
I´ll take into account your input in the following days.
regards,
Paco
Old 22nd April 2011, 12:38 PM   #4
smartx21's Avatar
Oh, I see... "Paco de Murcia"! Do you also play the guitar?
Old 22nd April 2011, 04:23 PM   #5
Pacorl's Avatar
I used to play guitar many years ago, but very poorly .
Broken amplifier - Hum in left channel. MaxWar Solid State 7 28th April 2011 05:51 PM
Help With Left Channel Hum Monjul Tubes / Valves 4 21st April 2010 10:24 AM
Can I have the sub woofer channel and the left and right channel as one? Boscoe Chip Amps 7 21st February 2010 05:56 PM
Hum left channel on Threshold SA3 (I know its not a pass labs but...) Tino Pass Labs 3 30th May 2008 02:53 PM
Need help with hum and faint left channel on my S5 Electronics kit Neville Tubes / Valves 4 15th January 2007 10:58 PM
Page generated in 0.09653 seconds (73.87% PHP - 26.13% MySQL) with 11 queries
