i built a stereo amplifier on 2 LM 1875. WHEN I START THE AMPLIFIER IT WORKS ONLY FOR 15 SECONDS NICELY AND THEN SHUTSDOWN, WHEN I SWITCH IT OFF AND SWITCH ON AGAIN IT DOES THE SAME WHAT COULD BE THE PROBLEM
#2 |
Why are you shouting? What is the size of your heatsink? E
#3 |
Heat sinks?
:)ensen.
Those who claim to be making history are often the same ones repeating it. |
#4 |
Yea, Bob Pease used old VW cylinder heads. Thermal resistance is supposed to be less than 0.5C/W
E |
#5 |
Hey, that woul make for a great converation piece for the living room! An amp, VW cylinder heads left and right. Better talking about than that sofa you made out of that old whiskey barrel I helped you empty! E
#6 |
is the problem because of heat sink
#7 |
It could be there is not enough heatsink to cool down.
There is a protection against overheat. Otherwise check you have everything put together right. Normaly LM1875 is easy to get to work. What is your power supply? VDC?
lineup |
#8 |
when i switch on the circuit it works fine but after few seconds it goes dead ,
when i switch it off and switch on it immediately then also it's dead but i switch on after 5 - 10 seconds then it works finely but again same thing happens i have attached a thick aluminum plate for heat sink can the problem be because of slew rate of TL072 ic (the slew rate is 13V/us ) or whether the circuit starts to oscillating. |
#9 |
It is nothing to do with TL072.
Are both channels doing the same? I should checkout that the supply rails and ground are correctly attached. LM1875 should take +/-21 Volt, I think. Another thing that can switch off the amp is output shortcircuit or too heavy load. Use one 8 Ohm or 10 Ohm power resistor as dummy load. Checkout what you have connected to output pins.
lineup |
#10 |
The pcb lay-out may be such that it causes oscillation. Show us your pcb lay-out and check the output of the amp with an oscilloscope. E
| My amplifier Using Tube buffer and LM1875 | Luck | Chip Amps | 26 | 7th January 2012 06:42 PM |
| 2 stereo lm1875 amps, 4 speakers, and a bunch-o-other stuff | churchwarden | Chip Amps | 11 | 10th December 2009 04:50 PM |
| FS: LM1875 Stereo Kits | swin1 | Swap Meet | 0 | 10th October 2009 10:19 AM |
| FS: LM1875 Stereo Kits (x3) FREE Shipping in Australia! | swin1 | Swap Meet | 7 | 12th September 2009 01:18 PM |
| compact lm1875 amplifier | Jamh | Chip Amps | 9 | 25th August 2009 12:50 AM |
| Page generated in 0.10248 seconds (77.71% PHP - 22.29% MySQL) with 11 queries |
