Dx Blame MKIII Supercharged will soon be released - Page 27 - diyAudio
Old 24th July 2011, 02:54 PM   #261
destroyer X's Avatar
Default Alex mm made both options
attached.
regards,
Carlos
Full throotle amplifier manufacturing; https://www.youtube.com/watch?v=iEXaSSlMEBg, Sample Dx Classic https://www.youtube.com/watch?v=fVvFrwl92RU
Old 24th July 2011, 02:55 PM   #262
Default Here you have more images
Attached.
regards,
Carlos
Old 24th July 2011, 04:18 PM   #263
besides dealing with the space factor of the larger board , how do you plan on getting any heat transfer with the pcb being between the outputs and that alu angle ?
sorry but this makes no sense to me at all .
cheers Woody
Old 24th July 2011, 04:38 PM   #264
Default This will happens in other forum...not here...in this forum, boards
may be the original...the ones we start offering...the old style..without "L" adaptor...if i understood well...this is what Byron will do.
About the other forum, despite it is not you should worry, we are dealing with this modification.
Majority of guys are Brazilians...not only from Brasil but my friends..people that has assembled one or two amplifiers from the "corporation"
They use "L" shape adaptors and they have protection boards (delayed insertion, off set protection and thermal protection) and they will connect the thermal sensor to switch off when reaching high temperature...and this may not happens because they will use their amplifiers at their home.
I will provide schematic to the ones want to make the protector...i have all plans and also they have boards...i have also boards here and they can copy to produce by themselves.
They will be stimulated to buy heatsinks that already has a flange to reduce thermal troubles... some thermal grease will be suggested and this may help a lot... avoiding the adaptor, using the special heatsinks Hugh Dean from Aksa uses, then no problems about heat transference.
They will know..all them...about the thermal issues....i have made several videos about it and all them will be published there.
Do not worry...uncle charlie will be dealing with this problem.... visit this link and watch loudspeaker protection....i will provide this schematic modified to use 64 volts supplies:
regards,
Carlos
Old 24th July 2011, 05:01 PM   #265
a.wayne is offline a.wayne  United States
Sin Bin
Carlos,
i believe he is talking about the ilustration posted , it shows the outputs attached to the board before going to the angle. I'm sure this was an oversight and not what is actually going to be done.
Old 24th July 2011, 05:28 PM   #266
Originally Posted by a.wayne View Post
Carlos,
that's exactly what i'm referring to a.wayne
Old 24th July 2011, 05:32 PM   #267
Default Well... i am confused.... boards offered may be these ones
Well... i have so many files here that i have to study.
So, no "L" shape adaptor to the diyaudio forum group buy...no flange, no special heatsinks.
Is that what you're talking about...i am Brazilian...my english is poor... write long text and explain what you mean with details or i will not be able to understand.
regards,
Carlos
Old 24th July 2011, 05:39 PM   #268
what i'm referring to are the illustrations in post #248 . the only way i can see that working is to have the outputs under the board but then you'd be using the board to clamp them which would be less than ideal .
cheers Woody
Old 24th July 2011, 05:44 PM   #269
Sin Bin
carlos as saídas tem que ir diretamente para o ângulo ou dissipador de calor não pode ser fixada para o conselho antes de ir ao ângulo ..
You have to mount outputs straight to the angle or heat sink .....
Old 24th July 2011, 05:46 PM   #270
Default I continue confused....i am showing the boards we gonna use
in this forum... the idea that is better to heat transference..the most safe idea.
Not what i like..these images are not my prefered..but this is what i suggest....this is what is needed...this is the best solution.
I am not understanding the meaning of your message Woody...explain using more words....i am not a native english speaking guy....uncle charlie is brazilian.
regards,
Carlos
File Type: jpg Good option...better to heat dissipation - 1.jpg (148.4 KB, 373 views)
DX BLame ES, ST, MKII, MKII Supercharged Groub Buy Interest Mitchel Group Buys 163 14th April 2015 04:32 PM
Are you ready to face strong emotions?.. Dx Blame MKII and the Supercharged release! destroyer X Solid State 671 22nd October 2013 04:37 PM
DX Blame Group Buy Rudi_Ratlos Group Buys 412 19th August 2012 05:00 PM
Dx Blame MKII and Dx Blame MKII Supercharged released NOW! destroyer X Solid State 1 29th October 2010 02:00 PM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 07:41 PM
Copyright ©1999-2017 diyAudio
