Dx Blame MKIII Supercharged will soon be released - Page 22 - diyAudio
Old 20th July 2011, 01:12 PM   #211
destroyer X's Avatar
Default Why you behave so unkind when people suggest modifications?
I do think people have not designed, have not tested... so... they do not know what they are talking about and trying to include their own ideas on it is awfull... they really want to go aboard a glorious ship..without pay for it...have not worked hard..have not take the risk to expose themselves to ridiculous if something goes wrong..but they want to put their name together yours.
No way!... some guys wants bonus without onus..wants glory without work for it..without take the risk.
regards,
Carlos
Full throotle amplifier manufacturing; https://www.youtube.com/watch?v=iEXaSSlMEBg, Sample Dx Classic https://www.youtube.com/watch?v=fVvFrwl92RU
Old 20th July 2011, 01:18 PM   #212
Default Oh!...my stock of foolishes is ending...i will think about that and may return
I will be back!
regards,
Carlos
Old 21st July 2011, 07:18 AM   #213
Damn. I knew you liked to talk but......wow.
Good sense of humour for your old age though.
Simon
Old 21st July 2011, 07:48 AM   #214
Default People feel shy to ask some foolishes.... or very basic things
and there are a lot of non skilled guys hidden.... i must inform them these things to make them appear from the bottom of their caves.
I do love to talk....yep.... as people is not posting questions..them i will post to myself.... maybe this way i will be answering something they would like to post as questions and they did not.
There's a lot that comes to my personal email with simple questions... this shows me they are shy to post questions..as they prefere something private.
Another thing, dear Simon, i had to be in evidence...i had to appear..... was a need to have posts appearing first place in the main page..because was running a group buy that was increasing orders in a very slow way...now it is fine..has a lot of orders (more than 30 heres and more than 50 in another forum).... who knows Simon?.... was because the noise i have made?.... maybe yes and maybe not... so... i do these things "just in case".
Actions can serve for nothing, can be bad and can be good.... these things i told cannot be bad for them.... for sure will be help...so.... this may be good.
Understood?
regards,
Carlos
Old 21st July 2011, 08:00 AM   #215
Default I have prepared, to myself, a home edition... a low power version
This helped me to compare amplifiers while using the same supply...the same range of power.
And i am showing you the schematic... basically the same amplifier... some parts replaced for tuning purposes and some parts are different because availability of these parts in my junk box.
It is not an amplifier released...it is just a curiosity for you.... i had fun producing smaller boards and using only two pairs in the output... it is sounding great..the same sound i have to the MKIII-Hx..... a little bit more high end because the smaller capacitor in the VAS....hehehe.... this made a lot of difference... VAS is the most important stage.... the most important tuning is made there.
The MKIII-Hx is already faster and have much more dinamics compared to the Supercharged MKII and the Dx Blame ST.... so....i found was unfair to compare them... would be a slaughter (heheheh)... then i decide to make them same power...same supply...this would result a more fair comparison.... sadly my camera is not able to register high frequencies..and there's the main difference between them:
‪Hx and St, a comparison‬‏ - YouTube
regards,
Carlos
Old 21st July 2011, 08:18 AM   #216
Default Have i to use Silver Mica capacitors?.... are they really better?
Yes...they are, in special when you face critical situations.... it is more stable..capacitance remains unchanged when facing variations of amplitude and frequency... and this does not happens with a ceramic capacitor.
In SSB transmitters... Radio Frequency transmitters... when you have variations of amplitude (suppressed carrier), we have to use these capacitors.... ceramics does not work fine there...so...in the output base to ground, as tuning capacitors, we always use silver mica.
But this is needed only to the Voltage amplifier stage (VAS)..because there you have huge variations in amplitude...there the operation is critical and we need stability...in other subcircuits in audio amplifiers, you can use other kind of capacitors...i do like ceramics because not coiled inside...their construction is not coiled as others...and coils are inductors...and inductors opposed to high frequency to cross...so.... ceramics are better as bypass capacitors, these ones in parallel with rail electrolitic condensers.
I am suggesting 103 and 203 ceramics to bypass condensers.
I do think the zobel filter capacitor should be ceramic too...because non coiled...but 100n ceramic is big to be used... we need there 100 to 250 volts insulation.... and this is huge when the dieletric is ceramic...and you have not a coil thing inside.
Input capacitor does not need to be Silver Mica...or Mica..... you can use ceramics (cheaper) or other.
regards,
Carlos
Old 21st July 2011, 08:25 AM   #217
Default Do different capacitor sounds? different brands and material used to construct them?
Watch this video and you will conclude by yourself if they sound or not.
I remember he had a second part...i could not find it now...but may be in his channel.
‪Guitar Tone Capacitors, part 1: Evaluating Material Types‬‏ - YouTube
Well..use a good amplifier and speakers to listen...or you will not able to evaluate.
Please, do not read video comments prior to listen and evaluate by yourself in order not to polute (influence) your own evaluation.
regards,
Carlos
File Type: jpg Use good speakers and amps for monitoring purposes.jpg (554.2 KB, 348 views)
Old 21st July 2011, 03:27 PM   #218
Default There's some strange capacitors in your amplifiers... and different values
What are they doing there in the circuit?
‪Supply rail resistors, bypass caps and oscilations in audio amps.- 1‬‏ - YouTube
‪Supply rail resistors, bypass caps and oscilations in audio amps.- 2‬‏ - YouTube
regards,
Carlos
Old 21st July 2011, 04:31 PM   #219
black is offline black  Romania
Send a message via ICQ to black Send a message via AIM to black Send a message via MSN to black Send a message via Yahoo to black
is a final schematic ?
Old 21st July 2011, 04:51 PM   #220
Default Can I use these transistors?
Originally Posted by destroyer X View Post
No!... these transistors are the ones i have.. so, i have tested the amplifier with them..naturally they may be something more guarantee to you..but several others..hundreds of other models of transistor will fit.
regards,
Carlos
Hi uncle Charlie,
You almost answer my question, but not quite. I would like to know what you think would be the audible effects of using 2SC5200/2SA1943 output transistors instead of your specified ones in the DX Blame MkIII Hx. I have a bunch of 2SC5200/2SA1943 leftover from previous projects.
Appologies if you have already answered it elswhere, but I could not find it.
Thanks,
Francois
DX BLame ES, ST, MKII, MKII Supercharged Groub Buy Interest Mitchel Group Buys 163 14th April 2015 03:32 PM
Are you ready to face strong emotions?.. Dx Blame MKII and the Supercharged release! destroyer X Solid State 671 22nd October 2013 03:37 PM
DX Blame Group Buy Rudi_Ratlos Group Buys 412 19th August 2012 04:00 PM
Dx Blame MKII and Dx Blame MKII Supercharged released NOW! destroyer X Solid State 1 29th October 2010 01:00 PM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 06:41 PM
Copyright ©1999-2017 diyAudio
