Dx Blame MKIII Supercharged will soon be released - Page 10 - diyAudio
Old 12th July 2011, 03:34 PM   #91
Bigun is offline Bigun  Canada
Bigun's Avatar
Carlos,
I notice you now use 1k collector load on VAS buffer device - to protect from destruction during clipping. Did you consider option of connecting the collector of this device to the output signal instead ? The output is nominally at ground, but when the VAS is most in danger is when the output is negative clipping and then the voltage on VAS buffer collector is low enough to prevent destruction. There is some impact on sonics, but it makes your VAS more bullet-proof and this idea is also patent free
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 12th July 2011, 03:40 PM   #92
destroyer X's Avatar
Default Good idea...i do think i have used for the Troyan, a more standard
darlington style VAS....thank you dear Bigun...now it was made...i left a couple of days waiting for suggestions, but now i put the machine to work.... in other words, the modification season finished.
I will try your idea to the next design. because becomes confused and troubleb when we have to change things, schematics, bom, pcboard layout and so on.... also when we have version 1.0, 2.0, 3.0 and so on.... this confuses a lot...i prefer to finish, to end and to start a new project.
Thank you very much..i was waiting Andrew T to say something...he said anything then i closed the design this morning and said to Alex to run the black and white images and post them in order to allow people to produce boards..so...no more changes...but i do like very much your idea and i thank you very much...i gonna check it in the future and i may use it and will say people the idea came from you.
regards,
Carlos
Full throotle amplifier manufacturing; https://www.youtube.com/watch?v=iEXaSSlMEBg, Sample Dx Classic https://www.youtube.com/watch?v=fVvFrwl92RU
Old 12th July 2011, 05:06 PM   #93
Bigun's Avatar
thank you Carlos.
So, how do you like this CCS-bootstrap ? I simulated this but never built it. What does it offer you that bootstrap does not ? I'm very curious about this feature.
Old 12th July 2011, 05:28 PM   #94
Default It looks that resulted in more speed...looks more dinamic and
also keept the blameless overall sound quality...i tried because i felt the CCS not very good... treble is very special in this one...i have to check it while using same power and same speaker... you know, to do a fair comparison with the Dx Blame ST...then i will be able to say something more about it.
I do suggest you to do the same...test it and compare with the CCS and also with the bootstrap.... CCS will loose...this i can say in advance.... try this idea you have simulated...better than my opinion is your own real world test... this may answer your questions better than i can do.... also, feelings, sensations, emotions, are very difficult to translate to words
regards,
Carlos
Old 12th July 2011, 05:37 PM   #95
One more question? Can his beast be on 50V?
Tanks
Old 12th July 2011, 06:45 PM   #96
Default Yes...no problems...it was tested in several different voltages
I am sure that from 20 plus 20 to 64 plus 64, the unit works fine and does not need modifications.
Naturally the output power changes, and also the need of so many power output devices..for instance, the 21 plus 21 volts i am using to test my second MKIII Hx reduced the power to 18/35/70 watts in 8/4/2 ohms... also increase the distortion from 0.008% THD to almost 0.04% THD and this means 5 times bigger distortion and this you feel, you listen and turn the sound less clear to our ears.
In the reality, mine second prototype is operating using a 21 plus 21 volts 800 miliamperes supply..so..i can have 18 watts maximum and even reducing the output from 8 to 4 ohms i will continue having the same power, because the supply...in this case i can decrease output impedance to 2 ohms and will continue to have the same power..no increasing..because the power output depends on the supply.
With 50 volts you will not have too much difference...but the power output will drop a lot man... power output gonna be less than 120W at 8 ohms...more or less 240 watts at 4 ohms and 400 watts at 2 ohms..your sensitivity will increase..you gonna need only 350 milivolts to drive the amplifier to full output power instead of 400 milivolts (sensitivity/gain resistor set to 390 ohms) and distortion will be 0.010 % THD instead of 0.008% THD...well... that difference we cannot perceive.... too much small increasing in distortion.
In the real world you will not have 50 volts.... when draining current you will have voltage drop and your power may be 80/160/300 watts depending your supply power.
regards,
Carlos
Old 12th July 2011, 07:12 PM   #97
thanks destroyer x, i will manage with 80W.
Old 12th July 2011, 07:14 PM   #98
Default Do your know your transformer power?
Because depending your transformer...if you will use a single transformer or two transformers.... well..we can study to allow you to save money..if was needed 3 pairs instead of 5, then i can calculate to you.
Inform if you know your transformer power... also the AC output voltage of your transformer... if you do not know your transformer power, then i can teach you how to discover.... send me a picture of your transformer together dimensions..then i will be able to imagine it's power by it's size.
regards,
Carlos
Old 12th July 2011, 07:18 PM   #99
Transformer is 500W 35/36Vac. One
Old 12th July 2011, 07:40 PM   #100
Default 500 watts transformer will produce 325 watts of audio power
aproximatelly....so, this may be your maximum power.... good to one channel...power may be 80 to a 100 watts RMS into 8 ohms..... fro 160 to 200 watts when using 4 ohms and may reach 325W when using 2 ohms.
You may need only two output pairs and filters can be 30 thousand plus 30 thousand microfarads.
Transistors suggested can face 4 amperes each one of them when submited to this voltage (50V)....and you will be draining 2.7 to each one of them...so...gonna be safe with 2 pairs IF you will be using MJL4302A and MJL4281A.
If you decide to use a single 500 watts transformer, then you will have everything divide by two...also a single transistor pair can be use to each channel...your power gonna be 40 to 50 watts with 8 ohms.... 80 to 100 at 4 ohms and will produce maximum of 160 watts per channel with 2 ohms load....no magic... audio power output depends on supply power.
Supply condenser must be 30.000 plus 30.000 microfarads...do not try to save money on that, please.
regards,
Carlos
DX BLame ES, ST, MKII, MKII Supercharged Groub Buy Interest Mitchel Group Buys 163 14th April 2015 03:32 PM
Are you ready to face strong emotions?.. Dx Blame MKII and the Supercharged release! destroyer X Solid State 671 22nd October 2013 03:37 PM
DX Blame Group Buy Rudi_Ratlos Group Buys 412 19th August 2012 04:00 PM
Dx Blame MKII and Dx Blame MKII Supercharged released NOW! destroyer X Solid State 1 29th October 2010 01:00 PM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 06:41 PM
Copyright ©1999-2017 diyAudio
