Dx Blame MKIII Supercharged will soon be released
Old 11th July 2011, 08:57 PM   #81
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Some more pictures.
regards,
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 12th July 2011, 07:15 AM   #82
Default What made the sound different compared to the original Blameless?
This combination of CCS and bootstrap..... watch parts marked with green lines.
regards,
Carlos
File Type: jpg What made the sound different compared to Blameless.jpg (91.3 KB, 419 views)
Old 12th July 2011, 07:45 AM   #83
drowranger is offline drowranger
Originally Posted by destroyer X View Post
regards,
Carlos
you have a very nice technique.fast and effective.no need for computer and software.I salute you!
Old 12th July 2011, 10:56 AM   #84
Default Oh! finally a friend recognize this is a nce diy way to do things
Exactly...all i need is a nail polish and copper boards...no computer, no board manufacturers...only hard work.
I have waited 20 seconds to rtch this board, and copper was thick...because of the chemical i am using...50 percent of hydrogen Peroxide (grade 40 of agua oxigenada) and 50 percent of hydrochloric or muriatic acid or spirits of salt
Thank you as you have made my day.... please inform your country my dear downranger.
Here you have it assembled and playing.....digital camera recordings does not make justice....treble is hair rising because of emotions this amplifier drives you.
YouTube - ‪MKIII Hx - one more assembled and tested‬‏
regards,
Carlos
Old 12th July 2011, 11:39 AM   #85
Josip_Del is offline Josip_Del  Dubai
What I wrote was not critic, just suggestion to save some from picture I see tin. And it is wary easy if you have printer and PC
Old 12th July 2011, 12:04 PM   #86
regards,
Carlos
I have seen your MKIII video in you tube with only one pair of output.Can't wait for the completed version with multiple output transistor.sounds GOOD on my headphone .Congrats!
You know Carlos I envy you and others when I see their completed amps. on post.In my place where I work as foreign worker even ferric chloride is very hard to find and most of my co workers says its illegal to sell it here.I'ved search on internet for possible replacement and you have proved that to me that it works using agua oxinada and muriatic acid.
Can't wait to get back to my country.
Old 12th July 2011, 12:39 PM   #87
Default I felt curious about your country, because the passion you have made me
think you may be latine....and i love to check these things...to study the way people feel and react.
Hydrogen Peroxide, or agua oxigenada is used by woman to light up their hair colour....also surfers in my place use it and go to receive sunlight to become blond.... hehehe....so, it is easy to find in drug stores.
The acid is also easy (here) as it is used for cleaning purposes...it removes rust from metals and also can remove paint from cement and concrete, even dry paint can be removed...so, it is used for building construction, cleaning and reform .... also easy (here) and cheap .... cost is around 2 USD a litter....and you spend just a small ammount each time, just to cover the board that must submerge into the liquid....acid itself , and alone, can do the job...but the free oxigen from the hydrogen Peroxide is catalytic, acelerates reaction and dissolves copper in 20 seconds.
regards,
Carlos
Old 12th July 2011, 12:41 PM   #88
Default No problems Josip, despite i am a little neurotic, i have
understood your intentions...was clear to me that you had no intentions to bother.
regards,
Carlos
Old 12th July 2011, 01:05 PM   #89
smartx21 is offline smartx21  Brazil
Send a message via MSN to smartx21 Dx Blame MKIII Supercharged will soon be released
Originally Posted by alex mm View Post
.... this time I made thinks much better , I have split the GND exactly in two, power ground and signal ground as Rudi Ratlos sugdested in PM .Thank Rudi
Alex.
Hi, Alex!
Could you please post the latest layout files so people can start thinking of building this beauty? Some guys are asking for them, and I would like to help.
Thank you very much!
Max.
Max.
Old 12th July 2011, 01:22 PM   #90
Default Yes Alexandru, you can release black and white images to allow people to etch
boards at home.
I am trying to increase recording quality, the camera's microphone is at the top of the camera, this results it captures more the ambience sound than the direct sound...i have pointed camera downwards in order to force the microphone cartridge to face tweeter and midrange drivers, then i had slightly better results.
My tweeter is not high quality..it is an old plastic diafragm tweeter that i captured from Bravox two way automobile speakers.... so... i already have losses there.
This camera encodes in wave format but with 8K or 12K sample...this is unable to record tones of high frequencies.... this mades recording almost absent of high frequencies.... i do think it is recording till 5000 hertz and anything more.... not very good to show the treble that is something from outspace.
I am using 100pf in the compensation..and i think 82pf may be even better as i have tried in the first prototype.... silver mica there, please.
YouTube - ‪MKIII Hx.‬‏
regards,
Carlos
Dx Blame MKIII Supercharged will soon be releasedHide this!Advertise here!
DX BLame ES, ST, MKII, MKII Supercharged Groub Buy Interest Mitchel Group Buys 163 14th April 2015 03:32 PM
Are you ready to face strong emotions?.. Dx Blame MKII and the Supercharged release! destroyer X Solid State 671 22nd October 2013 03:37 PM
DX Blame Group Buy Rudi_Ratlos Group Buys 412 19th August 2012 04:00 PM
Dx Blame MKII and Dx Blame MKII Supercharged released NOW! destroyer X Solid State 1 29th October 2010 01:00 PM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 06:41 PM
Copyright ©1999-2017 diyAudio
