Dx Blame MKIII Supercharged will soon be released
Old 23rd July 2011, 12:11 PM   #231
Move the 4component group of 1n4007,100nF, 1n4007, 4r7 up by ~0.1"
Bring the -ve trace through between the heatsink and the existing 100r.
Connect the 330r to this new -ve trace.
regards Andrew T.
Old 23rd July 2011, 12:25 PM   #232
alex mm is offline alex mm  Romania
alex mm's Avatar
.... no problem at all I can manage
Regards Alex.
Old 23rd July 2011, 12:58 PM   #233
meanman1964 is offline meanman1964  Belgium
meanman1964's Avatar
Regards Alex.
Alex,
Can you also make a board with the following dimensions 265mm x 115 mm instead of 265mm x 87 mm?This way I could use an L bracket like in the pic
Old 23rd July 2011, 02:09 PM   #234
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Yes dear Meanman..... board was made that way to reduce size and this way we would
be able to reduce price...but if you can have the same good price having bigger board...then go ahead..it is fine to me...i do like this way.. was not applied as a sacrifice in order not to increase price.
About that resistance, well folks, if you want you can forget that resistance..we can say folks not to install them in the board too...not the best solution to say that but we can do that in an emergency when Byron had already fixed all stuff and made agreements with his board manufacturer.... circuit can operate without the resistance to negative, because it is there because i desire to adjust both VAS transistors VBE according to my own needs..some "matching" of VBEs or if you want to understand different, some "unmatching" of VBEs i wanted to have there.
Bias, polarization will be there anyway...with or without the resistor... watch the diagram and you will see the circuit can flow this way too... simulations and also my prototype worked great without problems when i have removed that resistance from the circuit.
Of course i would prefere to have it..but if Alexandru , or Byron or Meanman, because their own reasons, decide to keep the circuit the way it is and inform builders to remove that resistance..then it is OK to me too...i want to make your life easier..and also to provide a very good circuit to the community.
Alexandru finding some time to do it (he is busy), also Byron and Meanman, then you should fix the stuff installing the resistor in the correct place.
regards,
Carlos
File Type: jpg We can let it out from the circuit too.jpg (24.5 KB, 285 views)
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 23rd July 2011, 02:26 PM   #235
Default Good!...it looks you have made changes Alexandru
Then send the fixed gerbers to my adress.... your have changed but uncle charlie email adress remains the same:
nanabrother@hotmail.com
We gonna be happy, not only me but also group buy managers Meanman and Byron will be happy having brand new fresh gerbers with all that stuff fixed.
regards,
Carlos
Old 23rd July 2011, 02:29 PM   #236
drowranger is offline drowranger
Default MKIII Home edition
Originally Posted by destroyer X View Post
that is already very good...but busy... very busy!
I am having two more foruns to feed with boards, and i want now a different kind of layout as these two foruns (SMPS and diyaudio) are using the same layout....i want a different style...your style man!
Also i want another option, a Mini Hx, or "The son of Hx" to offer.... the same amplifier having only two output transistor, a single pair..and without room for "L" shape bracket to have it small and cheap.
Please, present your layout here, or contact uncle charlie using email adress:
It is a non profit movement.... the same i use to do all these years..no one will receive any kind of payment or advantage..no boards as gift, anything..just our gratitude, the forum respect, the forum appreciation on you and your inclusion in the hall of fame from the Dx Corporation, second stage, main headquarters..with your picture surrounded by golden frame.
I have a demand...i want your board tested...if accepted, then must be tested prior to me to order and distribute...you must produce it, sample, and build, or must send me to me to build and test it... then we will start group buy using your gerbers (must provide them).
Also provide me all files from your software that can be different than Eagle...files you have used to produce your layout and to export files as Gerbers.
I want your authorization to use it for free, in wide world foruns.... without profit to anyone of us....no advantage to me, nor for you and not for the group buy manager... a free service for the audiophile community.
- "Join the Corporation where you have the good ones to be one of us!"
We are reaching 100 boards ordered...so...it is a sucessfull enterprise and i want you to join us.
‪Are you a good pcboard designer then i want you‬‏ - YouTube
regards,
Carlos
Old 23rd July 2011, 02:38 PM   #237
Default Excelent... despite i am not having free time to inspect in details
Seems you have joined all ground points to a single track... this is very good.
I could see a jumper... this is good too, because this way you made it better than use a long waving line around.
Thank you... i will give a check on that but gonna make is with calm... we have no hurry about...i gonna use new layout to November...so.... a lot of time we have to study things.
You have sent me strange gerbers.... i do think we need silk screen, copper tracks, drill holes and more two or three files (I have not knowledge about the stuff)... you sent me more than 20 files..hehehehe..... check if this is correct...i will send you some gerbers as example to you.
Thank you very much...but do it with calm, not needed to run this way...we will not use them now.
Please, inform your country and if possible update your profile including this information about you and more if you want... we will be glad to know you better.
regards,
Carlos
Old 23rd July 2011, 02:47 PM   #238
Default My pleasure
regards,
Carlos
Old 23rd July 2011, 02:54 PM   #239
Carlos, bigger boards will not increase price
Old 23rd July 2011, 03:15 PM   #240
are you sure?
Are there some PCB manufacturers that charge by the unit only and not by area?
regards Andrew T.
Dx Blame MKIII Supercharged will soon be releasedHide this!Advertise here!
DX BLame ES, ST, MKII, MKII Supercharged Groub Buy Interest Mitchel Group Buys 163 14th April 2015 04:32 PM
Are you ready to face strong emotions?.. Dx Blame MKII and the Supercharged release! destroyer X Solid State 671 22nd October 2013 04:37 PM
DX Blame Group Buy Rudi_Ratlos Group Buys 412 19th August 2012 05:00 PM
Dx Blame MKII and Dx Blame MKII Supercharged released NOW! destroyer X Solid State 1 29th October 2010 02:00 PM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 07:41 PM
Copyright ©1999-2017 diyAudio
