Old 20th April 2011, 08:20 AM   #1
Default Ampeg G-110
Hi, I have an Ampeg G-110, G110, G 110. Here is a schematic: Ampeg G110.pdf
The problem seemed like a burnt out / crackly volume pot that put out about half power (total resistance 50K ohms, rather than 100K.) I exchanged it and this didn't fix the problem. Seemed as if wiring the new pot into the circuit dropped the pot's total resistance. So I dove into some troubleshooting.
1) I found the juncture of IC1 pin 6 / Base of Q2 (the semiconductor / transistor labelled "Reverb Amp") reads 24 volts, rather than 13.5.
2) The Emitter of Q3 (labelled Preamp) reads 0 volts, rather than 13.
3) Q4, labelled FET on the schematic, was passing quite a bit of current in an unintended manner. I tested each transistor after removing it from the board like this: (link).
4) I think Q7 is functioning properly, despite initial concerns that the collector pin was broken off the TO-126 package.
Seems that the transistor package & the heat sink to which it's mounted serve as the collector: I do get continuity between the broken collector nub and the heat sink and I rightly measure 24 volts between a heat sink and ground.
I'm asking for diagnoses, next steps, and where can I find replacement parts? I'm quite certain I'll need a new Q4- "610291-1." Google gives me nothing, and there are no additional markings on the transistor itself.
Thanks, Cashin
Ampeg BA115 keeps blowing fuses Rotus623 Solid State 2 26th September 2010 11:02 PM
diy Ampeg preamp carrejans Tubes / Valves 2 9th May 2009 07:30 PM
Ampeg VL-502 aman74 Instruments and Amps 1 4th June 2008 01:53 AM
AMPEG amp convert satelitis Instruments and Amps 6 30th March 2006 04:56 PM
Ampeg Amp Value audiopro Instruments and Amps 0 2nd August 2004 03:09 PM
Page generated in 0.07200 seconds (66.85% PHP - 33.15% MySQL) with 11 queries
