11 month old NAD c315 BEE croaked...
Old 16th April 2011, 04:18 AM   #1
j beede is offline j beede  United States
Default 11 month old NAD c315 BEE croaked...
They sound good and punch above their weight but every NAD integrated amp I have ever owned has failed... Luckily I have only owned a couple. This time I am really disappointed because this little c315 BEE integrated was really doing a nice job in a modest media system--which was a new thing for us.
I had been leaving the NAD in "standby" so it could be turned on/off via remote since the mechanical on/off switch is on the back of the amp and is not convenient to reach in my rack. The amp is less than a year old. Today, instead of turning on and playing nicely it produced low output with heavy distortion for about 10 seconds then shut down with the red LED glowing. After cool down this sequence is repeatable. This model NAD does not have the external jumpers to allow separate testing of the pre- and power amp sections. During the brief distorted output phase I could hear the tone controls working so I believe the preamp section is okay. The L and R outputs both distort. Power supply? I would be happy to do some probing--if I had a schematic.
Anyone happen to know what usually fails from prolonged standby in this amp? Anyone know where I can get a schematic or service manual? The amp has a 2-year warranty but I am the second owner and per the manual the warranty is not transferable.
Old 20th April 2011, 09:43 AM   #2
eggontoast is offline eggontoast  England
Common failure on these amplifiers are the 10000uF smoothing cans. Take the top off and see if they have leaked or are bulging.
I have repaired a few of these now with these caps failed, also a couple of the smaller capacitors on the LT rails have a habit of drying out so just check for any bulging/vented caps.
Old 26th November 2012, 07:00 PM   #3
cookachoo is offline cookachoo
I too will be replacing the caps on my amp. But before shelling out on a pair of high grade caps, i wanted to check if using 8200uf caps would be ok. They are also 50v anyway,but is 10000 so different from 8200?
cheers
Old 26th November 2012, 09:25 PM   #4
Ian Finch is offline Ian Finch  Australia
Hi cookachoo. The manufacturing tolerance is quite wide for electrolytics; about -20/+50%, so being down by a nominal 20% is negligible, in effect.
Go ahead with confidence, though there are those who think in terms of the largest amount they can fit inside the case for some reason.
Ian
Old 26th November 2012, 09:57 PM   #5
Nice one ian. i'll be sure to post some feedback on the results.
Old 26th November 2012, 11:43 PM   #6
jaycee is offline jaycee  United Kingdom
elektrotanya has the schematic
This is one of their oddball amps that have bulbs in the supply lines. Never figured the point of that.
Old 27th November 2012, 09:38 AM   #7
Perhaps there is a better explanation but there are 2 raw DC supplies here. One is of 45V rails and this linked via the the bulbs, one in either + and - rail, to a lower set of 35V rails.
Presumably, this produces a safer form of rail sag, as exploited in some designs to prevent excessive dissipation with low (4R) loads.
It might make a bit of a light show with heavy bass!
Ian
Old 27th November 2012, 10:42 AM   #8
davidsrsb is offline davidsrsb  Malaysia
Light bulbs are much cheaper than power resistors on heatsinks
Old 1st December 2012, 10:51 PM   #9
hi ian. just some feedback with regards to fitting the capacitors. They came in the post and I fitted them same day......works perfect and my amp sounds superb. I fitted nichicons.
Regards.
Old 7th December 2012, 09:13 PM   #10
Have you read Nad's white paper about it NAD Upgrade Software and Documentation -- License Agreement/Disclaimer - NAD Electronics
11 month old NAD c315 BEE croaked...Hide this!Advertise here!
CD80 clock frequency 11.2896 to 11.0592? Sam Spade Digital Source 5 24th October 2010 04:44 PM
Vanishing Bee Catastrophe M50SNIPER The Lounge 27 4th February 2009 02:32 PM
Old new bee needs help to Identify NDtreehugger Solid State 8 29th August 2008 05:02 PM
New bee want help Hojvaelde Full Range 1 4th February 2008 11:24 AM
free 11 by 11 inch heatzinc good for class a karma Swap Meet 9 14th January 2007 03:30 AM
