Old 15th April 2011, 11:02 AM   #1
Default Krell KMA 100mk2 -> balanced input?
I'm wondering if a balanced input can easily be added to this amp. And if so, do you foresee any problem jumping the connection to create an XLR out as that is how the single ended connection is configured.
I don't have a manual for this amp, and Krell doesn't have one posted either, so I'm wondering what the oddball speaker out connection is. Did Krell have a proprietary speaker cable connection system back then? I can't seem to find any info on that.
Thanks.
Old 15th April 2011, 12:35 PM   #2
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
I gather you don't like to go Bananas.
Afair, the MKI had dual output terminals to go bi-wired if so desired. The MKII came in two versions with regular screw-me terminals and hide-the-Banana holes, parallel connections in all three versions.
Looks like Sponge Bob has killed another thread.
Old 15th April 2011, 04:35 PM   #3
I would like to add an XLR if possible so in a future installation I can move the amp to the basement and nearer to the speaker it will be powering. It's a matter of WAF due to too many large amps to power the 5.1 setup.
I've attached a pic if the back, and looking at the back:
a) on the RH side are two RCA's: either one can be used as an input and the other can be used as an output to another amp
b) toward the centre are two typical 5 way binding posts
c) in either side of the 5 way binding posts are the oddball connections I was asking about
Old 15th April 2011, 05:08 PM   #4
cbdb is offline cbdb  Canada
Do you just need XLR connections or do you actually need balancing too?
Old 15th April 2011, 05:42 PM   #5
You can add a Cordell Balanced input adaptor (jFET buffer) between the new XLR and the existing PCB inputs.
The adaptor provides sufficient current gain to drive the very low input impedance of the -IN pin through the Signal Ground connection.
regards Andrew T.
Old 15th April 2011, 06:01 PM   #6
Go Bananas on your wallet : Fischer-CAMAC type.
http://www.fischerconnectors.com
Old 15th April 2011, 09:18 PM   #7
The adapter provides sufficient current gain to drive the very low input impedance of the -IN pin through the Signal Ground connection.
I need to be able to run a long length of interconnect cable (~40ft), so balancing isn't as much an issue as being able to use XLR's. I'll check into the Cordell Balanced input adapter. Is there a link with some info? I guess I was hoping that given the brand, it would be balanced even though it didn't have the XLR connectivity.
I didn't price or research the Camac connection, but is there any advantage?
Thank you all for your input so far!!
Old 15th April 2011, 10:18 PM   #8
Best ones there are.
The outer part acts as docking link, then the inner (conducting) part slides out, into the target area and locks itself (sorta how ticks operate on a blood donor).
Link i gave you : http://www.fischerconnectors.com/htm...ng-System2.htm
In the KMA years, brands as Krell and ML were very much in the spotlights.
The Mark Levinson's dudes were very keen on Swiss manufacture Lemo plugs/sockets for interconnects and multistrands, nice exotic touch and plenty extra publicity for the same bucks paid.
Those companies spent plenty on ad campaigns in the day, along with loudspeaker brands as Infinity.
Not just in audio mags, the target customer profile included classic automobiles & sports cars, yachts, anything other in printing for cash unloaders.
Whenever i got me a US big boat glossy mag, it was a done deal it included a Lincoln Continental ad page and some fancy audio page, at the least.
Dan d'Man must have figured he could use a countermeasure by adding fancy Swiss lock terminals to the penthouse level monaural series.
(maybe just my imagination again)
Old 15th April 2011, 10:40 PM   #9
zeonrider's Avatar
Default SSM 2141
The simplest way is to use this:
Regards zeoN_Rider
Old 16th April 2011, 06:55 PM   #10
Thanks again for all the help!!
Toronto - Krell KSA-100MK2 clone boards and Glassware Aikido PCB twitchie Swap Meet 2 8th June 2007 03:12 PM
krell kma amplifiers adjusting bias anyone know anything ? zuki Solid State 16 24th February 2005 05:40 AM
Krell KMA-200 mk2 schematics Thomas B Solid State 1 18th September 2002 10:25 PM
Page generated in 0.09906 seconds (78.37% PHP - 21.63% MySQL) with 11 queries
