There has been some talk here about using light dependent resistors for volume control and maybe there are some technical arguments against that. I found this circuit which might be an alternative:
Audio electronic potenciometer |
#2 |
cmos switches can generate distortion.
Eric.
I believe not to believe in any fixed belief system. |
#3 |
#4 |
Don't know how the distortions compare.
I think I read some stuff somewhere that if cmos supply is highish voltage and switch source impedence low and switch load impedence is high then lowish distortion can be had. Analog devices had some very low distortion switches SSM2404 | Quad Audio Switch | Analog Switches | Switches/Multiplexers | Analog Devices There are other high quality volume controler ics available. Eric.
| Volume control on DVD player remote. Lose resolution at low volume? | Circlotron | Digital Source | 2 | 10th June 2011 07:20 PM |
| Paul Haynes LDR Volume and Balance with Remote Control (lightspeed, Lighter Note) | ua100k | Swap Meet | 2 | 26th April 2011 03:00 PM |
| Replacing broken volume control with digital volume control | Gunawan W | Solid State | 19 | 15th December 2010 10:46 AM |
| WTB: LDR-based volume control / pre | jdubs | Swap Meet | 7 | 2nd December 2010 01:50 AM |
| remote control motorised control for volume pot/knob | CharlesY | Parts | 0 | 25th July 2005 11:12 AM |
| Page generated in 0.07791 seconds (73.54% PHP - 26.46% MySQL) with 10 queries |
