bootstrapsCCS+T-TMC - Page 16 - diyAudio
Old 11th October 2012, 11:30 AM   #151
AndrewT is online now AndrewT  Scotland
But compensation is negative feedback !
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 11th October 2012, 01:29 PM   #152
dadod is offline dadod  Croatia
dadod's Avatar
Originally Posted by homemodder View Post
Andrew the compensation is moved not the feedback.
Its an old trick, youd probably get the same result returning the compensation to the base of inverting input.
Good result though, interesting stuff Dado.
Yes homemodder I now about that old trick, but I couldn't get stable simulation with close enough distortion, so I gave up with it and never triad it in real circuit.
dado
Old 11th October 2012, 01:49 PM   #153
Local negative feedback if you want to call it that not global.
Old 11th October 2012, 01:53 PM   #154
The issue is whether you get the same distortion figure with the same phase margin. In any amp compensation can be reduced for lower distortion but less stability results, thats not a good comparison.
Old 11th October 2012, 02:00 PM   #155
dadod's Avatar
Agree, I did it with similar phase and gain margin.
Old 11th October 2012, 02:36 PM   #156
I checked compared with post 1 and thats why I found good result, have you tried with the cascoded amp ??
Old 11th October 2012, 02:47 PM   #157
dadod's Avatar
Cascoded LTP or cascoded VAS?
Old 11th October 2012, 02:58 PM   #158
The hawksford cascoded vas.
Old 11th October 2012, 03:51 PM   #159
dadod's Avatar
Yes I tried with my TT amp but not with so good result. It could be that distortion was already so low (simulated) that improvement is not obvious. TT amp, 200W/8ohm, 701W/2ohm
Old 11th October 2012, 04:20 PM   #160
Default Email
Hi Dadod,
I sent an Email this morning. No reply yet.
I wonder if it ended up in your Spam bin?
regards Andrew T.
ThermalTrak+TMC amp dadod Solid State 633 16th December 2016 06:11 AM
MEMDIST POWER AMP + JC + TMC - help to set up padamiecki Solid State 8 10th January 2014 09:38 AM
Real World TMC/ETMC applications ostripper Solid State 23 14th December 2010 07:57 PM
What to do with TMC tube radio gear? diamondsouled Tubes / Valves 4 31st March 2009 01:30 PM
Copyright 1999-2017 diyAudio
