#141 | |
You can use 0.15ohm for those resistors. I made it of the six parallel 1ohm/0.5W resistors, look at the photo, only one set was mounted(right side). By sorting I suppose you meant matching. I did match hfe for the LTP and current mirror transistors using ordinary universal meter with hfe feature. Output transistors and drivers were from the same batch and used them with no matching. You can match as follows: Q2-Q3 LTP(glued together- or use thermotube) Q5-Q6 CM Q94-Q95 drivers Q8, Q10, Q96, Q97 output trs. Dado |
#142 |
I think I did not mention it before. Inductance L1 should be mounted on the PCBs back side parallel to R98.
dado |
#143 |
1. Why did you glue Q2 and Q3 together?
2. I asked about matching (not sorting...) in order to buy quantity of transistors before building, but I don't know how to do the practical work of matching. Nicola |
#144 | |
About matching you can find a lot of explanation even in this forum by searching. You can look here too: Matching Power and Driver Transistors I used ordinary multimeter with hfe feature. Dado |
#145 |
Hi Dado,
Should I isolate electrically output transistors from L bar ? Are the four screws for output transistors enough to maintain the board to L bar ? Nicola Last edited by vac231; 5th October 2011 at 02:16 PM. |
#146 | |
I think it is called TO-3P. If you look at the photo in #141 you can see two screws fixed from bellow. I do it first and then fix the transistors. Dado |
#147 |
sorry I had to say that you have to insulate the drivers and Vbe multiplier(BD139) also.
dado |
#148 |
I couldn’t resist but to try catalin a wonderfull sziklai to move compensation capacitance from the collector to the emitter of the LTP transistor.
Easiest way to tray that was this amp with the TMC. Here are simulations, it is possible to use smaller TMC capacitances and get good phase and gain margin. THD20k dropped from 0.000696% to 0.000249%. LTP emitter resistors are increased to the 220R, tail current increased by 50% and VAS local NFB removed. I am listening now this modified amp and I like the sound very much, for such simple amp it is amazing. dado |
#149 |
9dB reduction in distortion !
Can we call this relocation of the feedback Current feedback since it feeds into the emitter of the input transistor? Or is that again a mis-use of the term "current feedback"? |
#150 |
Andrew the compensation is moved not the feedback.
Its an old trick, youd probably get the same result returning the compensation to the base of inverting input. Good result though, interesting stuff Dado. Last edited by homemodder; 11th October 2012 at 09:45 AM. |
| ThermalTrak+TMC amp | dadod | Solid State | 205 | 13th May 2013 07:31 PM |
| MEMDIST POWER AMP + JC + TMC - help to set up | padamiecki | Solid State | 7 | 7th December 2011 12:34 PM |
| Real World TMC/ETMC applications | ostripper | Solid State | 23 | 14th December 2010 07:57 PM |
| What to do with TMC tube radio gear? | diamondsouled | Tubes / Valves | 4 | 31st March 2009 01:30 PM |
