Comercial or Diy amp for 300 to 400 U$$...any idea?
Wait |
#2 |
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#3 |
If you have a good DIY skill, DIY route is way better.
Can you source a used amp? Vintage amps have good quality transformer. This transformer is usually the most expensive part of a DIY amp and the used amp is usually cheap. But good quality circuit per dollar is only available in DIY. So you can use this DIY circuit to replace the original commercial circuit in the used amp. Refurbishing the look of the old amp will be part of a DIY activity. For any commercial circuit used by the old amp, you can find similar DIY circuit so you can upgrade the old amp using the original PCB. Of course, some commercial amps such as NAD have different topology that you may not be able to find similarity easily. But if your DIY skill is good enough, nothing you cannot do. But a bit electronics knowledge is required. Remote control is one feature that is useful but not easy to DIY. Think about having this control in the preamp. But I remind you good quality commercial preamp is too expensive. |
| Just an Idea? | Lightning2143 | Tubes / Valves | 3 | 16th February 2009 06:04 AM |
| Hello. I'm new, and have an idea. | wafflesomd | Multi-Way | 5 | 27th July 2007 01:25 PM |
| An idea! Fully balanced TDA1541A DAC idea. Please comment! | cartman | Digital Source | 8 | 17th July 2007 08:18 AM |
| New sub idea. Tell me what you think please... | chops | Subwoofers | 28 | 29th May 2006 04:19 PM |
| Page generated in 0.07679 seconds (69.67% PHP - 30.33% MySQL) with 10 queries |
