Seems there are two schools of thought for single ended VAS load - a bootstrap (AKSA, DX, TGM1) or a Constant Current Source made out of a transistor and LED or out of two transistors. People say the bootstrap sounds better. Hugh of AKSA fame says (on this forum) this is because the bootstrap provides some +ve feedback that helps deal with the consequences of speaker back emf on the gnf, and he also says that the capacitor rolls off gain above 100kHz allowing less Cdom. Others, particularly EVA say (on this forum) that the bootstrap is bad and is clearly inferior. Some don't like the use of a large electrolytic cap. Yet people like OS say (on this forum) that the bootstrap sounds better.
So which one ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#2 |
Is the answer to combine them - Bigun's Bootstrap ?
In simulations (notoriously unreliable for some) the current variations through the VAS device with a regular bootstrap can be simulated with Bigun's bootstrap using a modulated CCS (and the FFT looks 'nice' too). The advantage - no large electrolytic and you get to 'tune' the behaviour amongst others.
#3 |
Like many other similar questions, it depends. Of course I don't have sufficient knowledge to explain the physics/electronics, but I do know that if you don't have "ears" all you can do is "see" the measurements.
If you believe that simpler is better, always do it with perfection because simplicity requires attention to details. |
#4 |
My intuition is it will be worse. It will be good if we can provide the current exactly and sufficiently when we need it (just like what a ccs does) but without putting transistors there.
My approach is to pay attention to the power supply quality, short connection, capacitor quality and size. |
#5 |
IMHO either technique is viable and it simply depends on what you want. I've used both, bootstrap in earlier designs and generally a CCS these days, but I have recently been playing again with bootstrap. Bootstrap is nice and simple with just passives and has always sounded fine. Using a CCS offers a more technical solution that likely yields better measurements most times. So, are you more about measured performance or how you percieve the sound? I find the CCS crisp sounding and bootstrap a little softer, my own untrained perception. I don't have any sophisticated measurement tools, so I set up with a DMM and check on the oscilloscope to check the basics and then just listen.
---Jason Kuetemann--- The greatest trick the Devil ever pulled was convincing the world he didn't exist; and like that, he's gone. |
#6 |
This doesn't mean that I'm a bootstrap guy. In a complex circuit/situation this simplicity may not give benefit at all. In a top quality system, I think ccs is a must.
#7 |
From my experiments with modulation / no modulation of the current source in the Zen9 schematics, I concluded:
1) If one looks for drive and speaker control - better modulation and bootstrapping. 2) If one looks for ultimate transparency, microdetails and live-like sound - then no modulation, and removing as much as possible PCB traces and wires, where alternating currents walk. Shunt PS, even local ones for separate stages, is one of the measures for achieving this, it allows to localize the region where AC present. Important also to cut out the main PS from supplying AC currents to the schematic. These measures provide drastic positive effect for the sound, although measurements could be the same or even worse. |
#8 | |
This could be adressed by tying the bootstrap cap to the emitter of the CCS. |
#9 |
There is simpler way to combine bootstrap and CCS.
I am in process to test it in practice, as I was thinking for for some time about it. dado |
#10 |
I was wondering if anybody has tried Bigun's Bootstrap yet ? - believe it not, now that I no longer rely on spice I may actually try this out !
I'm also thinking about another type of 'CCS' that might sound better than a regular CCS and that would be the gyrator Wavebourn Tower-III High-end hybrid amp has anyone tried using a gyrator as a VAS load ? this is also what I'm thinking of trying. Only the resistor between base and collector on the gyrator device - move it over so that it's between base of the gyrator device and the amplifier output - and you get Bigun's Bootstrap again
| Help in HIP4081A bootstrap circuit | dileepkella85 | Class D | 2 | 19th March 2011 03:53 AM |
| Mosfet Quiet Bootstrap | acoustixman | Power Supplies | 1 | 16th October 2010 12:15 PM |
| Bigun's Botch Up amplifier | Bigun | Solid State | 56 | 24th April 2010 02:54 AM |
| Why bootstrap? | peranders | Solid State | 52 | 27th December 2007 04:25 PM |
| Aleph amp bootstrap - where to go? | Klaus | Pass Labs | 5 | 28th May 2003 09:48 AM |
| Page generated in 0.12557 seconds (81.31% PHP - 18.69% MySQL) with 11 queries |
