J-FET & MOSFET VAS with current NFB
Old 9th April 2011, 05:53 PM   #1
VladimirK is offline VladimirK  Uzbekistan
Default J-FET & MOSFET VAS with current NFB
This schematics has no capacitors in the signal path, and demonstrates wide pass band even with standard easy obtainable parts.
Output voltage is rather stable, within 10mV. It is adjusted by the R5* resistor.
40mA idle current through T2 and T3 was choosen for using them without heatsinks. By adding heatsinks, the current can be encreased correspondingly by adjusting (decreasing) the R7.
I put the schematics together on the breadboard, and made some measurements.
Maximum undistorted sine signal is 17V RMS, the clipping is nicely symmetric.
Also shown the 100kHz square wave (output amplitude is scaled to the input), and 1MHz input and output sine waves.
Old 9th April 2011, 06:46 PM   #2
lineup is online now lineup  Sweden
lineup's Avatar
It is not too often we see MOSFET in VAS.
But a pair of IRF610/9610 can deliver a good current with high speed.
Which shows in your images.
JFET at some mA will drive the GATES.
lineup
Old 9th April 2011, 07:09 PM   #3
I also plan to transform this circuit into a real power amp - by using special high Idss, high transconductance, low-Ciss j-FETs, like CP650 (or russian KP903A), we can achieve 100-200mA in the first stage, and to use 3A idle current through T2,T3 (these could be K1530 and J201). The only doubt, the current from power rails under signal is not constant, hence some special care is needed to power supply design.
Old 9th April 2011, 07:11 PM   #4
MiiB is offline MiiB  Denmark
with a cascode and and lateral output sets it can scale to a beautiful Poweramp...
Old 9th April 2011, 07:24 PM   #5
As for using laterals, I don't think it's a good idea, since with such a simle circuit we have to look for (transcondactance at idle current / Ciss) ratio, and hear Toshiba's MOSFETS seem to be more appropriate (or Fairchild's).
Old 9th April 2011, 07:48 PM   #6
Ohh you misunderstand me
I would insert a cascode to shield the Jfet from higher voltage... and put the laterals after the mosfet stage...with a simple resistor as a bias spreader...
This is similar to my take on Lineups One J-fet amp which i Really like.... but i really like the use of mosfets for a single ended VAS...I think it would make a very good amplifier...
Old 9th April 2011, 07:57 PM   #7
This is similar to Lineups One J-fet amp which i Really like..and have made PCB's for.. but i really like the use of mosfets for the VAS...I think it would make a very good amplifier...
This is a good idea, but me personally I shall try to stay with two stages only (Nelson Pass's school ...).
Old 9th April 2011, 08:06 PM   #8
lineup's Avatar
Nelson Pass school, of one or two stages and HEXFET output.
But he is just about the only one that can get low dist that way.
And even he must make some clever patented tricks to get it there.
lineup
Old 9th April 2011, 08:21 PM   #9
As much as I like the simple Pass low wattage amplifiers, then he too uses extra stage(s) to get to higher power levels...
Old 9th April 2011, 08:30 PM   #10
Bigun is offline Bigun  Canada
Bigun's Avatar
I say stick to your guns Vladimirk, build it simple and listen to it. I bet it'll sound great on a single large full range speaker - and will do so without being used above 1W.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
J-FET & MOSFET VAS with current NFBHide this!Advertise here!
A superior VAS clamp and VAS current limit for the Blameless. GK Solid State 128 19th October 2011 03:03 PM
Unstable VAS current in amp from Slone book andy_c Solid State 160 25th December 2009 08:57 AM
Voltage gain stage for Non-NFB MOSFET current amp gripracer Solid State 50 23rd October 2009 02:37 AM
Calculating VAS current for mosfet output bogdan_borko Solid State 21 11th April 2006 03:57 AM
