JFET input, MOSFET VAS, LATERAL output = Perfect!!
Old 30th May 2011, 10:41 AM   #531
GregH2 is offline GregH2  Australia
GregH2's Avatar
Default Near perfection....finely tuned
Hi All,
Well I just tried a few more things and now we're really getting somewhere.
First, I increased the input drain resistor to 1k to bring the current down to 4.5mA. All good, no adverse sonic affects.
Second, I added the filter cap to the input bias as lineup suggested. Not really any sonice affect, but clearly good practice.
Third, I added a grounding resistor to the input.
Fourth, I tackled the capacitive load overshoot and ringing square wave issue. I tried three things:
1) I wired a 4.7nF cap from the VAS to the output as was suggested here by Sonnya. This caused the amp to oscillate so I quickly removed it and aborted the idea.
2) I tried a 150pF miller cap. Made no difference.
3) I was so keen to try Hugh's idea of a cap from the VAS to the JFET source that I improvised and used 3x 150pF polypropylene in series for 50pF. Perfect. Now no capacitive load under 100nF makes any change to the 20kHz square wave that is worthy of mention. A 1uF cap will still make it do some funky things, but better than before.
It may be the placebo effect, but I would suggest that it sounds better too...
So ladies and gents, here is the current circuit. It is very good indeed. I think a change of VAS fet may make it even better!
Last edited by GregH2; 30th May 2011 at 10:47 AM. Reason: Had Hugh's capacitor value wrong...it was 47pF!
Old 30th May 2011, 11:12 AM   #532
AKSA is offline AKSA  Australia
Mike,
It's a pleasure to hear your kind rantings despite my best regards...... everyone has a point of view, and it's an intolerant fellow who can't handle that!
SWF,
I'm really pleased phase lead has had the desired effect. You'll be pleased to know John Linsley Hood loved this method of stabilising amps, and always suggested that it was best on its own, without a Miller cap if you could avoid it. Congratulations, you are certainly in good company now!!
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 30th May 2011, 12:11 PM   #533
GregH2's Avatar
Thanks Hugh, did JLH write any books? If so I need to get one!
Old 30th May 2011, 12:16 PM   #534
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
JLH always advised a bit more stabilisation rather than a bit less precisely because it made it sound a bit better
he wrote few books
http://www.amazon.co.uk/John-Linsley-Hood/e/B001HD0TGE
check this out
Old 30th May 2011, 12:40 PM   #535
GregH2's Avatar
Hugh, mikelm, all,
With the 50pf of compensation outlined in post 531, the square wave is now clean up to 100nf of capacitive load. I would expect that further compensation would improve things further. What are the pros and cons of adding more capacitance here?
Thanks for your input.
Btw, mikelm that link did not work, but I'll go search for jlh at amazon.
Old 30th May 2011, 12:42 PM   #536
here they are:
Valve and Transistor Audio Amplifiers
The Art of Linear Electronics [1993]
Audio Electronics [1998]
Old 30th May 2011, 01:45 PM   #537
GregH2's Avatar
Thanks Mikelm, I'm going to order what I can find of those.
Here is the current 20 volt peak to peak, 20kHz square wave with 7.27R and 100nF... Anything below 100nF looks much the same. 1uF is pretty messy, but a vast improvement on yesterday. Need I pursue this issue further or are these results good enough?
I have dropped the VAS current to 15mA as the devices were getting quite warm with no heatsink.
Edit: I posted the wrong photo. This is shot is actually with 75pf of compensation, but 50pf looks pretty much identical
Old 30th May 2011, 02:28 PM   #538
lineup is online now lineup  Sweden
lineup's Avatar
Hello swordfishy and mikelm
I have made an official version of Fetzilla
Eventhough people are free to build how they like
this is the one version I recommend people to build.
It is based on swordfishy's published amp, with super-good sound.
What is remarkable is that his amp is stable without compensation cap.
This is because of IRF9610 lower gain
but also emitter degeneration of VAS IRF9610 with one 49.9 Ohm capacitor.
This version below should be equally stable, sound good
and not give any headache with oscillation.
Fourier analyse at 1 kHz shows nice spectrum
with H2 and H3 sticking out. This is how we want it.
I be back with further tests later.
swordfishy
Could you setup this official version
should I be happy. Do it only if you want to.
lineup
Old 30th May 2011, 03:12 PM   #539
I would be interested to find out if this version with the CCS to the neg rail sounds as good as the the version swordfishy has built.
Personally I was so happy to see the critical FB point not connected to a power rail - thus with no possibility of power rail noise polluting the delicate signal . . .
. . . but if it sound the same or better when we do have a CCS to the neg rail I can implement exactly the same anti DC offset measures as Tim Andrews did which would be just great.
mike
Old 30th May 2011, 03:54 PM   #540
lineup's Avatar
hello mikelm
I'd be happy if you tested my circuit in real life.
swordfishy tested DC-linked version, with no big cap.
he was not happy DC-offset problems, like Hugh suspected.
I think you need not test the DC-linked version without cap.
It is simply not good and safe.
But the official version I posted now should not cause any problems.
I think it might sound good, too.
I suspect the VAS with IRF9610 is working wonders.
Only thing I forgot is one 2.2uF cap across the Gates of output.
Like in diagram below:
lineup
JFET input, MOSFET VAS, LATERAL output = Perfect!!Hide this!Advertise here!
10 Watt Single End, JFET input - Lateral N-MOSFET output lineup Solid State 86 4th April 2015 03:54 PM
Lateral MOSFET, How do I calculate power output synonymous Solid State 4 18th December 2007 06:54 AM
Calculating VAS current for mosfet output bogdan_borko Solid State 21 11th April 2006 03:57 AM
