Old 7th March 2012, 04:15 PM   #2251
Send a message via Yahoo to mikelm
Many here are driving O/P devices directly from the VAS with 10-15mA so the VAS is looking at the comparatively high o/p device i/p C - about 500pF in my case.
My VAS is driving into about 40pF which I believe is much lower than the devices you suggest and as has been commented on in this thread several times, lateral mosfets are very easy to drive - bottom line is that there was a perceivable improvement in sound quality when I added the drivers
mike
Actually I tried the 2sj 2sk devices you mentioned in the middle of my oscillation crisis and things just got worse.
Old 7th March 2012, 04:43 PM   #2252
kees52 is offline kees52  Netherlands
I did mean the zvn into powerfets, it is enough for one pair, and some limited bandwith, have you simulate that?
I like a little current and low impedance for mosfets, but I do most quasy.
Simple is your design, Hugh like that, I wil in future also try that.
happy designing.
Old 8th March 2012, 05:00 AM   #2253
keantoken's Avatar
I think Roender's RMI-FC100 would be a great starting design to convert to CFB, in order to achieve a CFB+folded cascode design.
Old 8th March 2012, 06:23 AM   #2254
keantoken's Avatar
It would be difficult or impossible to do a CFB+FC design because the signal has to be inverted in the VAS. So you would need an extra inverting stage, and that might moot any benefits.
Old 8th March 2012, 07:28 AM   #2255
GregH2 is offline GregH2  Australia
GregH2's Avatar
Originally Posted by mikelm View Post
Well, since I posted my last DC version here I've been travelling and doing other stuff.
As soon as I increased the voltage, the parasitic oscillations set it. I can hear Greg laughing . . . . I had to really work at it from several approaches to finally fix it.
mike
Haha, actually no I'm not. I feel your pain, though these days I understand how to deal with oscillation a lot more and it's not so much of a problem.
The problem with this amplifier topology, for me at least, is square wave overshoot. Specifically, correcting it without using an overly large output choke, which does remove a little urgency to the sound.
This is of course asssuming that you care what your square wave performance is like... even with bad overshoot it sounds pretty good!
Old 8th March 2012, 07:40 AM   #2256
keantoken's Avatar
One good way to get rid of overshoot is to make open-loop gain very low. To many that is not an attractive option.
Old 8th March 2012, 07:45 AM   #2257
Nearly every mod I did was to aimed at reducing ringing on square waves - the others were to reduce other types of noise
I tried every measure I could think of to keep the amp's rise time fast & minimising ringing.
Driving from a low impedance - less than 50R - and making the o/p device gate stoppers as small as possible are both useful measures in this regard and a good tight layout helps a lot.
The only other measure which works in theory is a cap across the feedback R this works wonders for rise time vs ringing - but I'm not sure I like the sound of it - I'll check again.
I do love the sound of this amp, when I returned home I was delighted just how good it sounded - but I suspect there may be others that just as good or better
Old 8th March 2012, 07:53 AM   #2258
Yeah, so far I always found I prefer the sound of fast, high feedback amps so long as they are very stable in the critical region.
Old 8th March 2012, 07:59 AM   #2259
tessier is offline tessier  Canada
Originally Posted by AKSA View Post
Yes, you should drop approx 200mV across this resistor.
Quite by chance, I discovered this about 15 years ago working on a cascoded VAS, I was amazed, but could never explain it.
Hugh
Hi Sir
Cascoded VAS, 200mV drop across a resistor in that VAS?
You was amazed, that's interesting.
Can you say more, any drawings?
Thanx
Paul
Old 8th March 2012, 09:33 AM   #2260
keantoken's Avatar
Mikel, a miller cap or a series feedback cap will decrease overshoot only by decreasing gain at overshoot frequencies; it will only give the appearance of a better behaved amplifier. It does not change the cause of the overshoot which is the resonance at GBP when undercompensated.
I think you should try TMC.
10 Watt Single End, JFET input - Lateral N-MOSFET output lineup Solid State 82 30th July 2009 06:23 PM
Lateral MOSFET, How do I calculate power output synonymous Solid State 4 18th December 2007 06:54 AM
Calculating VAS current for mosfet output bogdan_borko Solid State 21 11th April 2006 03:57 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
