Old 31st July 2011, 07:22 PM   #1611
kees52 is offline kees52  Netherlands
Originally Posted by mikelm View Post
Hi Kees,
That is a very nice circuit !
will have to try it sometime
well thank you, now you can use higer voltages with the limitations of the j fets.
Old 31st July 2011, 11:15 PM   #1612
keantoken's Avatar
My amp starts at 120mV today, over time it will drift to below 10mV, unless something changed while I slept.
It is frustrating to me, not knowing whether the harshness comes from the recording or the amp.
Kenpeter, I took a look at those dual Jfet and it turns out they were 2N5564, not 5464 as you had wrote! So I can use them as either the input or CCS, or both, barring excessive inter-jfet capacitance.
http://www.datasheetcatalog.org/data...shay/70254.pdf
- keantoken
Old 1st August 2011, 01:31 AM   #1613
GregH2 is offline GregH2  Australia
GregH2's Avatar
Kean,
Maybe you need some compensation, either phase lag or lead?? It certainly has a treble smoothing effect.
Old 1st August 2011, 02:02 AM   #1614
keantoken's Avatar
I have gone through many phases of adjusting my headphone amplifier. Generally what happens is I achieve greater resolution and a sense of space, and greatly improved clarity, but then the treble seems greatly emphasized, if not harsh. Is it possible it is because of my speakers?
I cannot be sure whether the harshness comes from the source or the amp. Once I switched back to my old Creative soundcard to help with harshness but again there was the loss of quality. Hmm. I wonder if positive phase shift in the treble is a factor here, because increasing the speed of the amplifier will decrease HF phase lag.
I added the VAS degeneration, and that calmed the sound a bit, but also seemed to lower quality in other areas. I am about to add the CCS.
- keantoken
Old 1st August 2011, 02:16 AM   #1615
You coulda used 6dj8 for all it matters...
Why we wasting the matched pair?
Old 1st August 2011, 02:54 AM   #1616
keantoken's Avatar
I don't have any other jfets.
- keantoken
Old 1st August 2011, 02:59 AM   #1617
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
You wouldn't find one jfet as orange glowing as 6DJ8 even if you had Jako's stash of semis.
Old 1st August 2011, 03:08 AM   #1618
Salas's Avatar
Are they full range drivers? They look rugged around sibilance frequencies. They also need a lot of step correction. Much higher sensitivity up high.
Old 1st August 2011, 03:15 AM   #1619
keantoken's Avatar
Yes, these:
Wild Burro Audio Labs - Fullrange Speakers - The Betsy & Betsy-K Drivers
- keantoken
Old 1st August 2011, 03:47 AM   #1620
Salas's Avatar
Have been messing with analogous Hemp FR8s and they needed a low Q wide band in series notch filter (parallel RLC) to tame. Else, they were high forward. Or DSP of course. Try with a parametric EQ module from your PC and do the in/out filter A/B test to get an idea. Using a mic is the key, but you can start by roughly evening out that chart by ear try outs. Just to have a hint if its the amp or not.
10 Watt Single End, JFET input - Lateral N-MOSFET output lineup Solid State 82 30th July 2009 06:23 PM
Lateral MOSFET, How do I calculate power output synonymous Solid State 4 18th December 2007 06:54 AM
Calculating VAS current for mosfet output bogdan_borko Solid State 21 11th April 2006 03:57 AM
Copyright ©1999-2013 diyAudio
