Old 7th April 2011, 11:38 PM   #1
pjwd is offline pjwd  Australia
Default active crossover unstable
Hi - I have built a balanced active xover for a woofer and it is quite noisy when input cable is plugged in and very sensitive to cable and equipment movement - it works very well when I can get it quiet but will not necessarily be quiet when I turn it on again.
this is the first time I have built anything like this and I expect it could be the way it is constructed causing capacitance and inductance in circuit as it is a point to point wiring on a tag board with large copper voltage supply rails - here is the circuit and a picture of construction.
I suspect it needs to be on a printed board - if someone could let me know if this is a hopeless way to proceed I would appreciate it
thanks,
Phil
Old 8th April 2011, 02:51 AM   #2
just another
wintermute's Avatar
Hi Phil, what are the opamps, and are you using any local PS bypass on them (ie small caps very close to the power leads of the opamps)? Low bandwidth opamps should be relatively safe, but high bandwidth ones are very sensitive to layout.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 8th April 2011, 03:16 AM   #3
Thanks Tony - they are all burson units and there are caps to a centre ground rail at each PS to opamp - I think they are .2Uf with a 10Uf at the end of the rails. slightly embarrased about the layout and soldering
Phil
Old 8th April 2011, 03:44 AM   #4
just another
wintermute's Avatar
oh ok "discreet" opamps... any idea what the bandwidth of them is? Just did a quick search and specs weren't forthcoming.
Have you tried it in a shielded case? Could simply be picking up rf or other airborne noise that a metal (grounded) case might eliminate. Also what are the black leads that aren't attached to anything? could they be picking up noise?
Tony.
Some of my photos
Old 8th April 2011, 04:42 AM   #5
Burson is a bit slim on info but they do get called wide bandwidth - I have made a rough zincalume box and that did not seem to help - I have put the PSU in a metal box - those black legs are the unused pins of the opamp.
My concern is that the basic layout being spread apart like that is inherently a problem compared to the short signal paths you get in a printed circuit board
Phil
Old 8th April 2011, 06:45 AM   #6
Calvin is offline Calvin  Germany
Calvin's Avatar
maybe the decoupling leads to probs. Instead of film caps of 2µF use ceramics (X7 or NPO) and parallel Electrolytics with a not so low ESR.
Keep the Decoupling Caps as close as possible to the OP-pins
jauu
Calvin
Old 8th April 2011, 07:00 AM   #7
Thanks Calvin - presume electrolytics allow flow to earth only - that makes sense - what is the ceramic for
cheers,
Phil
Old 8th April 2011, 07:46 AM   #8
just another
wintermute's Avatar
Hi Phil, being spread apart certainly means more area to pick up noise, I'm not an expert on layout, so someone else will be better able to comment.
The suggested use of ceramics is because they still function properly (as a capacitor) at very high frequencies, not all capacitors work as well at high freqencies. The wider the bandwidth of the opamp, the more liklely it is to have high frequency oscillations, so minimizing high frequency noise on your powersuply rails with ceramics (very close to the opamp supply pins) will help stabalise it. Go with the NPO's if you can, over the X7's
Tony.
Some of my photos
Old 8th April 2011, 09:38 AM   #9
What is that speaker in the pdf. Is it connected to this circuit...
What is op4
Gajanan Phadte
Old 8th April 2011, 12:19 PM   #10
Thanks Tony
Gajanan - the OP4 is a line driver - the speaker is an exodus tempest 15" - 2 of them in separate dipole H frames wired to give 8 ohm - the base is fantastc when no humm buzz etc. interferes
The filter is input buffer , shelving filter and lowpass cutting off at 250 Hz
Phil
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
Active crossover ivan-UTN-ARG Tubes / Valves 3 3rd December 2007 12:39 AM
Active crossover MaXiZ Pass Labs 9 22nd November 2003 06:04 PM
Active Crossover soundNERD Chip Amps 5 24th September 2003 01:39 AM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
Page generated in 0.10713 seconds (77.24% PHP - 22.76% MySQL) with 11 queries
