Howdy good folks,
Well I just received my first 555. It is in good shape, and inside everything appears sound. The DC at each channel is 48mv cold. The right channel sounds fine, while the left has an audible higher pitched hum, evident when the amplifier is turned off even. After powering on it noticeably increases in volume, and is unaffected by volume changes in input signal. The channel still puts out sound though. As of now I have ordered the four electrolytic capacitors for the board in the hopes that is the problem. They did not appear to be leaking or very bulged, however they are the original yellow ECI version. Any other ideas are welcomed. Thank you. Walker |
#2 |
Could be worn out potentiometer in volume control.
Changing electrolytic caps is good.
lineup |
#3 |
not really sure but i think the 555 features a Dc servo i think that many problems are caused by that poor stabilzation on the IC can cause this and other problems
kind regards sakis
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#4 |
Thanks for the help guys!
The mark 1 555 did not have the servo DC control, it used electrolytic caps. The very ones in the mail to my doorstep. Hopefully this will be the fix. The gentlemen I bought it from said he had a shop check it and they said it "needed capacitors". Maybe this was correct. I sure hope so, because everything else looks great. I'll update Monday when I get those capacitors in. Walker |
#5 |
Hi Walker,
I don't know if your problem is the same as mine but I will share my experience anyway. I had hum in the left channel of my Adcom 535II. I took it to an authorized Adcom service center who charged me $60 to tell me the hum was within spec. Within spec was not good enough for me so I fixed the hum myself. The shielded wire from left input RCA to amplifier PCB was right beside the power cord on the inside but the wire had no shield for the last inch on either end. I replaced the input wire leaving the shield on as close to the end as possible. Hum gone. M |
#6 |
Martyn,
Thank you for your response! is this similar to what your hum sounded like?? YouTube - video-2011-04-11-16-29-12 ADCOM 555 Test.mp4 Thanks! Walker |
#7 |
Hi Walker,
My hum was 60Hz. Your hum is as you described - much higher pitched. Our problems are different. Sorry. M |
| Adcom gfa 555 help | 406vette | Solid State | 34 | 15th October 2011 03:34 PM |
| Adcom GFA-555 MKii blown channel checklist? | l.a.rossmann | Solid State | 0 | 10th May 2009 07:39 AM |
| Adcom GFA-555 | claiborne | Solid State | 8 | 27th September 2007 10:20 AM |
| FS:Adcom GFA 555 and GFA 5300 | trusound | Swap Meet | 0 | 13th December 2005 05:06 PM |
| Page generated in 0.08932 seconds (72.60% PHP - 27.40% MySQL) with 10 queries |
