Old 5th April 2011, 05:57 PM   #1
Default How to add EARTH symbol in LT Spice IV?
Hello...
I im just playing with LT Spice IV and have figured out most part...but don't know how to add EARTH symbol in schematic.
I know that GROUND symbol is 0 (Zero).
Any help are welcome..
Old 5th April 2011, 06:21 PM   #2
aparatusonitus's Avatar
Between "Wire" and "Label Net" find "Ground" button.
Non é mai abbastanza...
Old 5th April 2011, 06:47 PM   #3
ok...then opens dialog box saying
GND(global node 0)
COM
ABC (in box is 0)
So default set in ABC is 0 which correspond to GND( As GND is node 0)
So where i find EARTH or what should i put into ABC box?
Old 5th April 2011, 08:47 PM   #4
You don't have to click on ground symbol and open dialog box...just put it on the workshit. Or you can open dialog box and in ABC type "EARTH" or whatever you like.
Old 5th April 2011, 09:37 PM   #5
just another
wintermute's Avatar
As spice is a simulator I don't think that earth is particularly relevant... I assume you mean safety earth as opposed to ground. You could always make your own earth symbol in the editor and save it as a component I guess.
You could use a label (output) and just put the word EARTH in it.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 6th April 2011, 06:04 AM   #6
I need EARTH symbol for simulating amplifier design...without EARTH symbol my simulation does not work...
Old 6th April 2011, 06:23 AM   #7
MiiB is offline MiiB  Denmark
earth is the triangular symbol next to Wire in the top navigation bar..don't look for it in the components library..
Old 6th April 2011, 07:13 AM   #8
just another
wintermute's Avatar
Hi robydream, Then you need the ground symbol! You said in the first post that you knew that the ground symbol was 0V and that you wanted an earth symbol instead.
Attached are pictures of the ground symbol. If that doesn't help either then iether you are missing something, or I am!
Tony.
Some of my photos
Old 6th April 2011, 07:18 AM   #9
Wow....Wintermute.. You should be writing manuals..
Old 6th April 2011, 07:24 AM   #10
just another
wintermute's Avatar
Hi MiiB I'd rather not! working in IT it becomes second nature to do screen shots of stuff as trying to explain something is often difficult, and a picture says it instantly
Tony.
Some of my photos
LT Spice design ianmgreen Software Tools 8 6th April 2011 01:17 PM
LT spice DC .op function nicholas1113 Solid State 0 23rd November 2009 05:33 AM
LT-spice VS Eagle... CAD cooperation... MiiB Solid State 5 15th May 2009 09:52 PM
Help with LT Spice Bonsai Solid State 9 5th September 2008 12:32 AM
Caution! LT-Spice users ! sam9 Everything Else 0 20th December 2003 09:38 PM
Page generated in 0.10942 seconds (76.52% PHP - 23.48% MySQL) with 11 queries
