Preventing Thumping sound
Old 5th August 2003, 06:55 PM   #1
Alvinttt is offline Alvinttt  Singapore
Default Preventing Thumping sound
Hi, anyone out there knows why I still get Thumping sound on my Loudspeakers, when I shut my amp, I've installed a speaker protection, but the thumping sound is still, there only when I turn off the amp. By the way I tapped on the amp's power supply for the speaker protection circuit, is that the reason.
Alvin
Old 6th August 2003, 05:54 AM   #2
EchoWars is offline EchoWars  United States
EchoWars's Avatar
Sounds like your output relay is not shutting down fast enough. You need it ot release as soon as the power switch is turned off. To do this, usually a transistor is coupled to the AC coming out of the transforner (before the bridge) through a diode and a small cap.
See the attached drawing. Your circuit is probably very different, but the idea of the fast shutoff on power down is the same and can be adapted very easily.
Old 6th August 2003, 06:10 PM   #3
Hi, do you mind if i post the speaker protection circuit, for you to have a look, you could then tell me how to do the mod, thanks for enlighting me on the topic, I'll have the schematics posted as soon as you agree. and thanks again.
Old 6th August 2003, 07:04 PM   #4
EchoWars's Avatar
Post away!!
Old 6th August 2003, 11:17 PM   #5
dutch diy is offline dutch diy  Netherlands
dutch diy's Avatar
Send a message via ICQ to dutch diy
Well, I don't know where you got this diagram from. It seems to me that this entire circuit introduces a hell of a lot of overspeech between Rch and Lch...
Old 7th August 2003, 12:07 AM   #6
EchoWars's Avatar
With 22K resistors and a 100f cap going to gnd? Not a chance. The input is from the output of the amp.......
IIRC, this circuit is lifted from an old Pioneer or Kenwood (or was it a Marantz..??) Been too long. However, it doesn't do jack to the circuit except to protect from DC at the speaks.
Preventing Thumping soundHide this!Advertise here!
My woofer is thumping (not when I want it to) RSBosma Subwoofers 8 13th April 2007 06:15 PM
Thumping from left speaker when volume is low dru85 Tubes / Valves 2 22nd June 2006 04:47 PM
Hafler DH-120 thumping & cracking when power on smoken_hot Solid State 11 23rd March 2006 07:24 PM
DIY system setup - muting, de-thumping, spkr protection, remotes etc ... paulspencer Everything Else 5 6th January 2005 12:29 PM
Playmaster 300W amp humming and thumping ccoutts Solid State 12 4th August 2004 12:58 PM
