All MOSFET Amp - with improvement potential?
Old 2nd April 2011, 06:12 PM   #11
wahab is offline wahab  Algeria
If THD is not the main concern, (about 0.02%), a symetrical differential + vas
using a pair of low power bjts to drive a few lateral fets pairs is the way to go.
Since the psu has relatively low voltage, you can increase the
quiescent current to something like 120mA/device and get
class A at higher level than with bipolar outputs using the same
current, thanks to the lfets caracteristics..
Indeed, it will blow out any F4 or other Fsomething like amps...
Old 2nd April 2011, 06:42 PM   #12
lineup is offline lineup  Sweden
lineup's Avatar
The problem is 2SK213-216/2SJ76-79 are hard to find.
Dgikey has 2SK214 and 2SJ77
FETs - Single | Digi-Key
lineup
Old 2nd April 2011, 06:50 PM   #13
3 pairs of 2SJ162/2SK1058 per channel will do it just fine.
I use the older siblings 2SJ48/2SK133 in such an arrangement,
since i downgraded the PSU from 2X55V to 2X22V DC...
Old 2nd April 2011, 07:04 PM   #14
knutn is offline knutn  Norway
So maybe 2sk214/2SJ77 as vas transistors...
and 3 pairs of 2SJ162/2SK1058 as power outputs will do it....
Old 2nd April 2011, 07:25 PM   #15
lineup's Avatar
One thing with 2SK214/2SJ77 is they are LATMOS.
So, have much lower VGS for given current.
Maybe like 1 Volt instead of 4 Volt to give 60mA bias.
lineup
Old 2nd April 2011, 08:25 PM   #16
Jay is offline Jay  Indonesia
Banned
I like your spirit!!!
20W is not too useful for me. There are so many good amps within this power rating that I cannot decide which one is better than the other.
But if it is subjectively better than F4 and is using laterals, I'm looking forward to building it
Old 3rd April 2011, 05:22 PM   #17
Federmann is offline Federmann  Czech Republic
Federmann's Avatar
Send a message via ICQ to Federmann All MOSFET Amp - with improvement potential?
Here is my
Old 3rd April 2011, 07:44 PM   #18
Federmann, the noise density vs frequency of your amp show
an overshoot at half a megahertz, which tells that your amp
has a gain overshoot at the said frequency.
The low pass input filter cancel this resonnance seen from
the input of the amp, but this will not change tha fact that
internaly, there s a large phase dip at this frequency, leading
to mediocre stability..
Old 3rd April 2011, 08:38 PM   #19
Federmann's Avatar
This is the noise Operating amplifier
All MOSFET Amp - with improvement potential?Hide this!Advertise here!
Need to know my system's (Bryston & B&W) potential heliumflight Subwoofers 2 20th October 2008 07:40 PM
t-amp + one speaker , can i get full potential? jaste Class D 2 15th September 2007 09:28 PM
Is there an improvement potential, or are these trash? canakas Multi-Way 20 19th June 2007 05:21 PM
Sonic Impact T-Amp Definitive Improvement List? ps_mrwonderful Class D 31 16th June 2006 02:17 PM
Symm-Amp Improvement tab30 Solid State 8 23rd April 2004 12:09 PM
Copyright ©1999-2017 diyAudio
