Old 1st April 2011, 06:45 PM   #1
knutn is offline knutn  Norway
Default All MOSFET Amp - with improvement potential?
I am planning to build the MOSFET amp attached, but I would like to replace the VAS transistors IRF610/9610 with better types, preferably MOSFETs. I have tried to find low cap, high wattage types without any luck. I also intend to run this amp without global feedback. Any suggestions?
Old 1st April 2011, 07:00 PM   #2
lineup is offline lineup  Sweden
lineup's Avatar
I only know IRF510/9510 is a bit lower capacitance.
lineup
Old 1st April 2011, 07:39 PM   #3
lineup's Avatar
What voltage supply?
lineup
Old 1st April 2011, 09:10 PM   #4
nigelwright7557's Avatar
Nothing wrong wit hthe 240/9240 combo in the schematic.
I have done numerous designs using those MOSFETs and they all sound good.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 2nd April 2011, 12:53 AM   #5
Jay is offline Jay  Indonesia
I forget where this circuit is from, but are you sure it is good? It looks like the designer wanted a symmetrical circuit while the mosfet is less complementary than bipolar?
And what do you mean with "without any luck"?. How about 2SK213-216/2SJ76-79? These are lateral mosfets not vertical like the IRF.
I have found in many amps using the IRF610/9610 that the mosfet is the limiting factor. Luckily the MOSFET used in the JLH 80W is a lateral one (tho the IRF also fits there)...
About IRF510 (as per Lineup suggestion), I'm aware that there are many manufacturers but from my experiment/observation/search, the IRF610 is the best (soundwise), not IRF510. For higher power IRF530 is my favorite.
Old 2nd April 2011, 06:02 AM   #6
lineup's Avatar
Here is another take on ALL MOSFET.
+21/-21 Volt. Gives max 14 Watt.
Shows very good figures.
Now, I do not know how to test for noise.
lineup
Old 2nd April 2011, 06:10 AM   #7
lineup's Avatar
IRF610 has somewhat higher RDSon than IRF510.
Maybe that's why it is more popular.
lineup
Old 2nd April 2011, 09:44 AM   #8
Thank you for your replies. I forgot to say I have a 2x18V 500 VA transformer and two quite large heatsinks, so I am planning to run it in Class A, about 25 W into 8 ohms. This makes it possible to not have feedback from the output, but from the VAS instead. the design is my own, the symmetrical input is maybe not necessary...
Old 2nd April 2011, 05:43 PM   #9
The circuit topology is imo "tailored" towards class-B. For class-A, we already "have" Pass Labs' F4 which is also about 25W into 8 ohm, using similar components as yours. Of course, it can be more fun to have own design regardless of quality. But isn't it better to follow the proven track? What I mean is, if you ask for expert's help here, they may suggest you to change your amp into something that is completely different.
Old 2nd April 2011, 06:04 PM   #10
Yes, F4 is a nice amp, but I need voltage amplification. and I like your proposal of 2SK213-216/2SJ76-79. I have looked at their data sheets, and these transistors seem promising. But do they sound better than the IRF's?
Need to know my system's (Bryston & B&W) potential heliumflight Subwoofers 2 20th October 2008 07:40 PM
t-amp + one speaker , can i get full potential? jaste Class D 2 15th September 2007 09:28 PM
Is there an improvement potential, or are these trash? canakas Multi-Way 20 19th June 2007 05:21 PM
Sonic Impact T-Amp Definitive Improvement List? ps_mrwonderful Class D 31 16th June 2006 02:17 PM
Symm-Amp Improvement tab30 Solid State 8 23rd April 2004 12:09 PM
Page generated in 0.10813 seconds (79.61% PHP - 20.39% MySQL) with 11 queries
