Which amp design sounds the best Which amp design sounds the best - Page 2 - diyAudio
Old 29th March 2011, 08:30 PM   #11
Bill Fuss is offline Bill Fuss  United States
RIP
The MyRefC chip amp would be the only one that I could recommend from experience. It is quite remarkable, but not really in the same league as a Pass amp. I've never heard a Quad so I can't make a comparison.
Old 29th March 2011, 08:46 PM   #12
weskoki is offline weskoki  Europe
weskoki's Avatar
Bill would love to hear more about the difference between these amps!
I do agree that Pass would sound more detailed
Old 29th March 2011, 09:07 PM   #13
RIP
I've built quite a few Pass amps, the Alephs have a lush liquid sound with varying degrees of detail depending on many things. This is probably OT. You can PM me if you wish.
Old 29th March 2011, 09:22 PM   #14
jemraid is offline jemraid  United Kingdom
Hi all,
For the reasons above I am going to make a Jean Hiraga 'le monstre' originally designed to be the solid state's answer to the valve 300B.
The thread on this forum is here, this is page 74 and post 733 is the one to read to begin with; Hiraga "le monstre"
Cheers - Jim
FH3 build using very simple tools and a point to point Gain Clone with largish power supply. http://www.jasread.com/fh3/index.html
Old 29th March 2011, 09:41 PM   #15
suntechnik is offline suntechnik  Russian Federation
Originally Posted by bluegrass View Post
Any recommendations for top designed Gainclones etc would be great too.
Something like an amp base on LME49811 + SANKEN ALLEGRO STD003 or OnSemi Thermaltrack has very good reviews that might be almost equal or just equal to class A amps. For the first project it would be more convenient to order a kit with ready to go PCB.
I would say that sound quality very dependable on passive components - power supply electrolytic & decoupling capacitors, attenuators etc. It is possible to get a pretty decent sound from an LM3886 or LM1875 based amp if treat ICs right.
Old 29th March 2011, 10:21 PM   #16
ostripper is offline ostripper  United States
ostripper's Avatar
I debated whether to even comment here , but here goes....
#1 - "warm sound" ," natural", "powerful"," transparent",dry ... all snake oil terms loosely dropped to make $$$$. An amp should be invisible ,it should be just your preamp or source with 32db voltage gain along with several thousand current gain. Any deviation from this is error. At clipping, this is different. An amp can clip "sharply" or "smoothly". Either way , this is a error in amplification and basically describes the tube Vs. Solid state controversy. Not counting this error , two amps that are run optimally might sound just SLIGHTLY different by design , or inadequate design .. or for having a different power supply (big factor). Again, this is an error as it deviates from the perfect "wire with gain" ideal (the invisible amp).
#2 - "class war" - Why would you burn 2000 watts to hear only 400 of them ?
Some do as they say it sounds better. The amp actually just makes a different "error" than one of another class would (AB or D). All 3 classes can be made to make the smallest of "errors" (.001%THD). At this point of "fanatic" engineering , we humans would not even perceive these differences.
I have heard 200 watt class A's sound exactly like 200w class AB's until you reached a very dynamic passage that took advantage of the AB's greater efficiency. All this is measurable and predictable by the operation of these topologies. Knowing "which was which" would be the only factor different between the two to subjectively bias the assessment.
#3 - If someone has a preference to "color" their sound , leave that to the many different loudspeakers/crossovers or diverse source manipulations, (tube preamps - 30 band EQ's , DSP processing). If a amp sounds "harsh" or "muddy"
(BAD ) , this is a result of a bad design choice that can be measured and predicted (cheap power supply , junk semi's bad design or a REAL bad layout). Just another error which makes the amp "visible".
Oh .. come on !!! , " lush liquid sound" ... would one get wet ??
Sanken = transconductance tailored for audio (no IRFP's in my amps)
OS
Wanderer - my travels.... Facebook - davyjones lockre -
Old 29th March 2011, 11:15 PM   #17
Bigun is offline Bigun  Canada
Bigun's Avatar
where to begin!
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 29th March 2011, 11:27 PM   #18
Bigun's Avatar
Bluegrass,
you weren't happy with a hot amp being left turned on (valves) - this would seem to rule out most Class A amps, they are all by nature going to run hot unless you have oversized heatsinks for a given idle current.
for a Class AB amplifier, solid state, state of the art - it's not necessarily going to be a simple project. My best sounding SS amp was fairly simple [designing TGM3 - output Triples ] but I would also suggest looking at this one: RMI-FC100, a single stage audio power amplifier
Old 30th March 2011, 02:05 AM   #19
qusp is offline qusp  Australia
qusp's Avatar
yes, without the desire to get down into the nitty gritty, i really dont see how you can build a top shelf performer of any type, except of the buy it yourself variety. i especially feel that sjostromaudio's smd gainclone is going to be beyond your ability and the research/reading needed to do any of these well is substantial.
only option is where all the design choices are made for you imo, such as the pansonaudio kits. these are the ones i was recommending before and someone else since, utilizing the lme49810/11/30 driver chips to drive mosfets, thermantrak, or other 3 pin transistors and you can fairly easily buy a couple and try different output devices
Old 30th March 2011, 03:18 AM   #20
ashok is offline ashok
ashok's Avatar
If you want to build something that sounds good but isn't expensive to try , then build an LM1875 chip amp. Typically 20 watts per channel and sounds good. After you listen to that and compare with your set up you can determine which way to go .......and that will be more expensive and possibly require more energy and time to complete.
A single stage 6922 preamp might give you the sound you like even with a ss power amp. Tubey but detailed. Parts do matter !
Maybe you should build the tube pre amp first ?
Cheers.
AM
Which amp design sounds the bestHide this!Advertise here!
50L6GT & 6L6GT sounds ?? papanohn Tubes / Valves 13 10th February 2013 01:51 AM
arcam alpha 8 amp sounds lifeless racman Solid State 16 30th March 2011 04:57 AM
Sounds By Design Functional Audio Art trusound Vendor's Bazaar 0 8th July 2010 07:03 PM
ROTEL amp sounds dull Bartt Solid State 35 28th March 2009 07:43 PM
New amp sounds too controlled ... what to fix Coolin Solid State 72 8th September 2008 04:21 PM
Copyright ©1999-2017 diyAudio
