I'm using small package transistors for my P3A, and I want to add another pair. How can I parallel these transistors?
Thanks |
#2 |
0.1 ohm 3W resistors in the emitters of both pairs.
#3 |
Look at Rod's P27 power amplifier.
#4 |
lineup |
#5 |
Like this? Or?
Will there any increase in power? |
#6 |
R13s goes to emitter side.
#7 |
Guys, you are all but publishing Rod's schematics here. It might make it easy to teach with the full, unpublished diagrams and make it easy for cloners but it's his business and not your IP.
regards |
#8 |
I think he is glad anyone is interested in his his amplifiers.
Image is just a link to his site.
lineup |
#9 |
You have confused emitter and collector.
Best use 0.470 or 0.330 Ohm
lineup |
#10 |
Apologies guys, you are right Lineup, as Rod now shows part values on his designs.
regards |
| Transistor choice for P3A | ChrisJennings | Solid State | 14 | 10th July 2011 05:00 AM |
| Parallel output transistor matching | AW-tech | Solid State | 8 | 29th November 2009 02:42 AM |
| Parallel or Transistor assisted chip amp ? | ashok | Chip Amps | 39 | 15th September 2008 12:41 AM |
| Can bias transistor mount on top(body) of output transistor?? | Leolabs | Solid State | 23 | 16th February 2008 12:35 AM |
| LM317 with a parallel transistor for current? | Progg70 | Power Supplies | 2 | 31st August 2005 05:01 PM |
| Page generated in 0.09518 seconds (74.07% PHP - 25.93% MySQL) with 11 queries |
