This amplifier takes a lot from Douglas Self blameless.
It is amazing how easy we can make a very low distortion amplifier. Does not take much. Power is with low THD 200 Watt in 2 Ohm 100 Watt in 4 Ohm 50 Watt in 8 Ohm
lineup |
#2 |
THD is at max nominal output. See images.
8 Ohm - 0.0011% 4 Ohm - 0.0012% 2 Ohm - 0.0016%
lineup |
#3 |
All just #'s , man ! Add TMC and that drops to .00008%. In real life , layout and parts selection (Mje350 vs. 2sa1381 , etc.) will make more impact (below). Choices of cascoding and LTP device selection are the only remaining factors as the THD is so low that noise,hum and PSRR become the only remaining considerations.
OS
Mongrel website , always current and updated : http://67.248.209.21/D%3A/WEBSITE/ Last edited by ostripper; 24th March 2011 at 06:25 PM. |
#4 |
The input uses one pair of JFETs.
This avoids any troubles and capacitor to fix DC-Offset. Minimum of currents gives minimum of offset voltage. Tha gain is set for nominal 1 Volt RMS input. Gv = 21 JFET pair runs at 4 mA each. Are 2SK170GR, 5 mA devices.
lineup |
#5 |
What is one TMC, ostripper.
I have never used one. Are they expensive. Real life. Unfortunately I have no possibility to build anything. I know most posters here understand this is is a careful SPICE design. This is absolutely no secret. Those who wants good amplifier can do so ... or not. I have seen people build many amplifiers of more crappy quality.
lineup |
#6 |
OPS is also a factor , add a triple EF or a lateral as output stage and you can refine the amp for the purpose intended. THD and the "charactor " of the resulting amp will be changed. TMC is just a "hat trick" discussed in the Cordell thread that will , in real life, allow the amp to sound "first watt" at 100 watts.
The resulting amp is pure "wire with gain" (below).. add a cascode for Jfet or super low noise IPS. OS
Mongrel website , always current and updated : http://67.248.209.21/D%3A/WEBSITE/ Last edited by ostripper; 24th March 2011 at 06:41 PM. |
#7 |
Top of input is a mirror. fig.1
VAS are 2 transistors in complementary foldback. fig.2 VAS is biased by a current source 5 mA VAS supply lines are filtered 4.7 Ohm 2.200uF
lineup |
#8 |
Output. fig.1
3 pairs MJL3281A/1302A driven by BD139/140 0.22 Ohms emitter resistors VBE multiplier one BD139 All red transistors on heatsink
lineup |
#9 |
Your OPS looks "wrong" , my example is "tried and true" (2.2R basestoppers - EF2 with 220R/10uF- driver Re/"charge suckout cap"). 3 pair is good for 4R sub use (I have one of them, too).
1k B-E resistor ??? PS - the .01R's are just to test for driver currents... OS
Mongrel website , always current and updated : http://67.248.209.21/D%3A/WEBSITE/ Last edited by ostripper; 24th March 2011 at 07:34 PM. |
#10 |
Here finally the complete Lu Blame.
Lu Blame
lineup |
| Dx Blame ES .... based into the Blameless, i am trying a new amplifier | destroyer X | Solid State | 1826 | 12th February 2011 07:11 AM |
| Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST | destroyer X | Solid State | 4 | 25th September 2010 06:41 PM |
| WTB in Oz: 150-200 watt stereo power amp | otto88 | Swap Meet | 4 | 20th December 2007 05:06 AM |
| an 1192 200 watt amplifier | tryonziess | Chip Amps | 1 | 14th April 2007 11:38 AM |
| Quality of Hammond 300 series power transformers compared to 200 series? | G | Tubes / Valves | 8 | 21st September 2003 02:27 PM |
| Page generated in 0.11563 seconds (74.41% PHP - 25.59% MySQL) with 11 queries |
