diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Cyrus II 120v Transformer (http://www.diyaudio.com/forums/solid-state/185645-cyrus-ii-120v-transformer.html)
Tazzer9999 23rd March 2011 07:21 PM
Anyone scrapped a cyrus II with a good transformer? 120V not the 240V one, will pay for it and the shipping
Anthony
jaycee 23rd March 2011 08:27 PM
The transformer is nothing special, it is 28-0-28 200VA I think. A suitably sized 2x30V transformer should work fine.
tiefbassuebertr 23rd March 2011 10:09 PM
as I know, the manufacturer was "Holden & Fisher" - the same brand used by Naim Audio.
check out this thread:
http://www.diyaudio.com/forums/parts...nsformers.html
If you need a replacement from currently production, I would prefer follow brands:
Transformers and inductive components by Tauscher
open toroidal transformer
info@tauscher.com
and
Standard Products – Overview Plitron
General technical techinfo@plitron.com
General sales sales@plitron.com
ask there about your wanted parameters and delivering sources for small quantities of standart devices; I don't think, that a custom made torodial device is necessary.
cchean 11th April 2011 08:28 AM
I believe your best bet wound be to buy a parts unit online. They do come by pretty often, it's just a matter of patience.
Since this thread is about the Cyrus II transformer, I was wondering if anyone has this information. I have a Cyrus II that is for 240V mains. Does anyone know if these are convertible for 120V operation? I had a Cyrus II for USA use that had only two wires (black & red) coming out of the transformer primary. Please advise. Thanks.
Carlos
Tazzer9999 11th April 2011 01:57 PM
2 Attachment(s)
Originally Posted by cchean (http://www.diyaudio.com/forums/solid-state/185645-cyrus-ii-120v-transformer-post2534480.html#post2534480)
Carlos
If this helps I did re-wire a Cyrus PSX to 120V from a UK Model, Cyrus had left the dual voltage leads i just had to figure out the wiring
I took the Brown and Black wires coming out from the transformer and wire tied them to the Red wire to the power switch
Then take the Blue and Red wires coming from the transformer and wire tied them to the Brown wire to the power Switch
Then if using the PSX and Cyrus II together you yank out the fuses from the Amp and do not even plug it in to the wall (unless using the phono stage that is)
As far as I can tell the Cyrus II did not have the dual voltage transformers, maybe due to size restraints inside that cramped shell, the PSX has plenty of room.
I plan on getting a 2nd PSX at some time to bi wire / bi amp a pair of Mission Argonaughts to really rock the place
Anthony
Resources saved on this page: MySQL 18.75%
