Recently I acquired a Sansui AU-D11 MKII in working condition. The only problem is selector knob, volume and input connectors.
Since I have heard great things about this amp, I want to turn it into a poweramp. But im a bit stuck...
Is it possible to connect a pre amp directly to the Driver Amp Circuit board (F-4266 & F-4267) or will this also bypass the differential stage?
http://el-post.com/doc/au-d11ii-opt.pdf
