Old 22nd March 2011, 09:51 PM   #1
DjLeco is offline DjLeco  Romania
Send a message via Yahoo to DjLeco
Default Final test: Module Leco vs Crown Powertech Series Amplifier
I decided to make an comparative test between mine AB class module amplifier vs. Crown Powertech Series Amplifier.
Dropping power supply to around +/- 77Vdc, to achieve around 500 Watts on mine module.
Both receiving same signal at inputs,both with 4 ohm dummy load on outputs , both calibrated for same tension on output at 1000Hz, means both are equal output power for 1000Hz, so input controller knob, adjust equally both amplifiers, any difference could very easy observablle, so any difference between them are shown.
To mentionate, Crown amplifier is with patented IOC Led (Input output Comparator) wich monitors any distortion , equally or greater than 0.05%, in entire amplifier bandthwidth
http://crownaudio.com/pdf/amps/iocpaper.pdf
WAITING FOR COMMENTS.
Calibrated probes:
Leco AB Module vs Crown Powertech Series Intro
YouTube - Leco AB Module vs Crown Powertech Series Intro.MOV
3,3Hz Sin
3,3Hz Tri
3,3Hz Sqr
30 Hz sinusoidal, max output
YouTube - Leco vs Crown Part 1.MOV
5Hz-30Hz sinusoidal, triangular, squarewave
YouTube - Leco vs Crown Part 2.MOV
30Hz-20Khz-8Hz, sinusoidal, triangular, squarewave
YouTube - Leco vs Crown Part 3.MOV
Dummy loadresistors
http://www.youtube.com/watch?v=M7vOAmCH3Pk
And here some tests with module equipped witg 5 paris of 2SA 2SA Toshiba's output devices , supplied at +/- 100Vdc
8Hz Sin
8Hz Sqr
30Hz Sin
30Hz Sqr
100Hz Sin
100Hz Sqr
1000Hz Sin
1000Hz Sqr
10000Hz Sin
10000Hz Sqr
20000Hz Sin
20000Hz Sqr
100000Hz Sin
Dummy load cooling down.
YouTube - Rezistenta la racire
If anyone could calculate Slew Rate of mine module, regarding pictures above at, supplied at +/- 100Vdc, will be very appreciate!
Also any comment will be appreciate too!
Crown DC300A and test equipment! deyjavont Swap Meet 7 23rd November 2009 03:46 AM
TDA1541A - Double Crown - Myth or Fact - How to Test poynton Digital Line Level 9 18th June 2009 11:32 AM
Crown D-Series Bridge Mono Modification dakine Solid State 4 5th February 2009 06:50 PM
final aleph 3 sound test jeapel Pass Labs 4 16th May 2006 01:22 PM
Cambridge Crown Series specifications Toshito Multi-Way 1 21st December 2002 01:22 PM
Page generated in 0.09539 seconds (69.58% PHP - 30.42% MySQL) with 10 queries
