F5 no caps in amp stage,,,why is it good?
Old 22nd March 2011, 01:53 AM   #1
Outside The Box is offline Outside The Box  United States
Default F5 no caps in amp stage,,,why is it good?
As a beginner amp builder, i'm going to build the F5..I've noticed a few comments about no capacitors in the amp stage..Am i reading this right, and if true, what are the plus's(+'s) or negitives of this design...Thanks, les
Old 22nd March 2011, 02:10 AM   #2
dave_gerecke is offline dave_gerecke  United States
Hello Les, I can't speak from experience on this particular design, but in general, if you have no capacitors in the signal path it reduces distortion. This is because capacitors (and all other components) have some degree of nonlinearity. This nonlinearity is what introduces the distortion. The ultimate goal of an amplifier designer/builder is the "straight wire with gain". That is the goal that still eludes all of the amps out there. Admittedly, there are some that are very close, but nothing is perfect.
Peace,
Dave
Old 22nd March 2011, 02:17 AM   #3
Thanks a lot.I'm going to appreciate my build even more, the more i know about the little things
Old 22nd March 2011, 03:07 AM   #4
wakibaki is offline wakibaki  United Kingdom
Banned
Positives
1. It's simple.
2. It's straightforward to build and set up.
3. There are no transformers (except the one in the PSU).
4. There are no caps in the signal path.
5. It has a usefully high input impedance.
5. Response goes down to DC, up to RF
Negatives
1. Response goes down to DC, up to RF
2. There are no transformers (or caps in the signal path), so
3. It will take a small DC input and drive a large current through your speakers, destroying them, if you don't take measures to prevent it. The obvious measure is to have a series capacitor in the source, which is what you were trying to avoid. Ho hum. You'll still get DC offset, so you might want a cap at the output...
4. It wastes a lot of power.
5. It takes ~1 hour to warm up.
w
Old 22nd March 2011, 05:13 AM   #5
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
maybe because its stable, without it, thus not needed, or wanted
Old 22nd March 2011, 06:02 AM   #6
ostripper is offline ostripper  United States
ostripper's Avatar
That's the question.. is the lack of phase shift or simplicity worth the risk of a catastrophic meltdown ?
Whether it is "good" or not is not the issue. IS IT WORTH IT ?? Most of the class AB's at DIYA will run input capacitor-less (it's not a stability issue) ... some actually do with a DC servo. Even those servo amps recommend minimal DC offset at the source. The source , preamp , and anything else upstream will have varying degree's of phase shift to begin with .... so it is anal to worry about it at the input of the main amp .The only exception would be with Bi or tri -amped active setups.There , you would just use the same amp (topology) for all.
OS
Wanderer - my travels.... Facebook - davyjones lockre -
Old 22nd March 2011, 08:16 AM   #7
Samuel Jayaraj is offline Samuel Jayaraj  India
To me it sounds like that folks who are in the Solid State forum most of the time are not very familiar with the Pass Labs forum and that is natural.
The comments about no caps in the amp stage of the F5 refers to the absence of any type/value of decoupling caps for the power rails. As to why it is so, I don't recall having seen any convincing reason and Nelson also has not told us why? I posed the question myself, as I am designing my own PCB for a modified F5 and have not heard anything concrete.
So now you can comment on the pros/cons of using/not using decoupling caps on the amp board, when you have separate PSU board and PSU cables.
Sam
Old 22nd March 2011, 08:37 AM   #8
ostripper's Avatar
Default No caps ??
Hmmm ???
Working on just these things... so that's the ??? Nothing wrong with the main caps on the OPS PCB , just run a separate return to star.... eliminates the inductance of the wire but complicates board/ chassis layout. Separate PS boards w/ wires can be coaxed to behave as well , just (properly) decouple at the power board rails. Leach explains about the high Q circuit formed between a length of wire + the normal .1uF rail cap , he eliminates the issue with a 10-100uF. The F5 will amplify VHF , so that high Q might be more of a issue.
wow ! that's a nice CRC PS .
OS
Old 22nd March 2011, 08:52 AM   #9
CBS240 is offline CBS240  United States
CBS240's Avatar
I agree with this. PS caps should be somewhat near the load for them, that being the output stage. I have discovered that it is worth the extra effort to design the PS and the amp on the same PCB, such as in this one. You have to be aware of the high current return paths so they will not cause interference. Although since this amp OPS is a full bridge, there is no speaker return to GND.
...and the next updated version (in process) still a bunch of work yet, hope to finish it soon.
All the trouble I've ever been in started out as fun......
Old 22nd March 2011, 08:59 AM   #10
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
naah
it's just cheaper without caps anywhere
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
F5 no caps in amp stage,,,why is it good?Hide this!Advertise here!
FS: F5 Amplifier Kit - Boards, Heatinks, Power Caps, Input Caps, RCAs, Binding Posts gripracer Swap Meet 17 6th November 2013 02:28 PM
zaph sr71 good match for f5 anonomouse Pass Labs 10 12th January 2011 06:16 AM
First Watt F5 as I/V stage? Skorpio Pass Labs 0 1st May 2009 10:20 AM
F5 Power Supply Caps Seem Small NV&H Pass Labs 3 23rd January 2009 01:41 AM
Is it possible to get good bass out of a SE two stage amp? MikeW Pass Labs 10 10th February 2006 01:35 PM
Copyright ©1999-2017 diyAudio
