This unity-gain follower is an audiological UFO:
It is adjustment-free, requires no thermal compensation, has no feeedback, no servo, can even work with fake or reject transistors, and yet offers low DC offset and sub-ppm linearity: |
#2 |
A "Current Dumping White Follower" - CDWF, not bad !
Without any further in-detail inspection this device seems only to be very linear as long as its bias/idle current into the load is not exceeded, right ?
My amplifier is very musical: It accompanies myself on the grand piano, that's not half bad ! Last edited by Jon Lord; 24th March 2011 at 02:51 AM. |
#3 |
What's Q4 doing?
#4 | |
In this case, the idle current is less than 50mA, and in the sim, it operates at up to 2.5A^. Q4 is part of the current mirror supplying Q7 a scaled version of Q5's collector current. |
#5 |
Im 100% sure, what I said.
Q3 is essentially held at constant current, up to the point, where more than -Ibias have to be supplied to the load, then it rises. This means a rise of output impedance outside this crossover point and thus lots of distortion. For this reason the amplifier works nicely at bias currents above 4A ... ![]() I think my guessing is more accurate than your simulation !
My amplifier is very musical: It accompanies myself on the grand piano, that's not half bad ! |
#6 | |
Anyway, I'm in the process of perfecting the last details in the ultimate simulation: the one that uses solder, bolts, heatsinks, and similar components. I am not too anxious about the result: I have already physically tested the most critical and contentious part of the circuit elsewhere, and it works as expected. Here, it is combined with a Taylor follower, but I don't think the end result will differ much from the sim (which, BTW is what I expected). |
#7 |
Most time switching on your brains helps before doing a simulation, especially if you use a simulator, which is intended for SMPS simulations and you try to judge your amplifiers by THD1k at 10V.
And also: what is immediately obvious for some people, might be a preoccupation in the view of other people, but it nevertheless could be true ... ![]() Did you try a DC sweep (-10..+10V) on V1 and look at the difference between input and output ? Did you have a look at the difference between input and output with a 10Vp 20kHz sine ? This should be a very ugly waveform with some neat spikes of switching distortion in it ... This circuit is certainly not better than 0.01% THD20k in real life, perhaps 0.005%, if you use better semiconductors and a very very careful layout. But you can prove the opposite, if you have a prototype running soon ...
#8 |
One advantage of Taylor, CFPs, and current dumping in general, may not be immediately obvious:
Emitter that must be the "follower" can be held at constant current. And thats quite different than simply throwing a CCS under an emitter. |
#9 |
[QUOTE=Elvee;2511348]This unity-gain follower is an audiological UFO/QUOTE]
did you built it? and know the sound?
regards, Pawel |
#10 |
some questions after the simulations:
regards, Pawel |
| Stereoscope Leader | Rafael L | Analog Line Level | 0 | 29th May 2009 12:15 PM |
| Need help with DC follower/peak follower HELP! | gain-wire | Parts | 4 | 8th July 2008 03:32 PM |
| how do i cut sonotube and keep the cut straight ? | zuki | Subwoofers | 27 | 11th July 2006 05:12 PM |
| Question about direct coupling a anode follower into a cathode follower. | G | Tubes / Valves | 45 | 29th July 2004 06:47 PM |
| Micromega Leader | Fin | Digital Source | 0 | 15th July 2004 02:49 AM |
| Page generated in 0.13932 seconds (62.48% PHP - 37.52% MySQL) with 11 queries |
