Old 19th September 2012, 05:38 PM   #21
Bigun is offline Bigun  Canada
Bigun's Avatar
I'm always on the look out for a current buffer that I can put a triode VAS in front of. Why would I pick this options over a number of alternatives (I'm not trying to be combative, just want to learn why) ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 19th September 2012, 07:47 PM   #22
Elvee is online now Elvee  Belgium
Elvee's Avatar
I certainly wouldn't push any unwilling individual towards this option.
It is undoubtedly an interesting one: it has the ability to produce a result that transcends the crap material it is made of, but the beast isn't easy to tame:
I've had some problems, one totally unrelated to the topology, a very unusual defect of one of the transistors and the other was a high frequency oscillation (several MHz).
I could trace the origin of this oscillation: it was caused by the wirewound 0.33 ohm emitter resistor.
I made a quick and dirty fix, a 100n ceramic in parallel. Probably not optimal but sufficient to go on with the tests.
This could be incompatible with:
You have to decide for yourself.....
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 19th September 2012, 08:04 PM   #23
CBS240 is offline CBS240  United States
CBS240's Avatar
Uh, er... HEC mosfet follower with paralelled output devices and a beefed up bootstrapped driver stage.
I currently am devising something like that using a low gain ECC88 bias at a constant plate current as a balanced VAS, driving 2 HEC follower stages for a balanced output. The EC circuit has enough emitter follower buffers that it has a very high AC input Z, so as not to load the plate.
All the trouble I've ever been in started out as fun......
Old 20th September 2012, 07:36 AM   #24
Elvee's Avatar
J. Broskie also has some nice, proven solutions. They are a safe option, but of course not half as interesting, challenging and effective as an UFO like Unigabuf
Old 20th September 2012, 04:38 PM   #25
Bigun's Avatar
Yeah, it's always difficult not to get attracted to these new ideas, they look like a lot of fun but you are right that I wouldn't necessarily go in this direction if I'm after something relatively foolproof. And at the moment I'm leaning more towards the latter, but I always keep an eye out for the new.
I've not considered HEC. I've not seen it used extensively and am not convinced from what I've read that it offers a real benefit over many other negative feedback topologies. Perhaps it's an idea worthy of renewed interest.
how do i cut sonotube and keep the cut straight ? zuki Subwoofers 28 10th July 2012 11:56 PM
Stereoscope Leader Rafael L Analog Line Level 0 29th May 2009 12:15 PM
Need help with DC follower/peak follower HELP! gain-wire Parts 4 8th July 2008 03:32 PM
Question about direct coupling a anode follower into a cathode follower. G Tubes / Valves 45 29th July 2004 06:47 PM
Micromega Leader Fin Digital Source 0 15th July 2004 02:49 AM
Copyright ©1999-2013 diyAudio
