Old 24th March 2011, 03:15 AM   #11
ostripper's Avatar
If I had a commercial laminator for 100-200$ , "fab in a box" with the thermo- reactive foils for both the tracks and screen sides , I could be my own fab house. With just the primitive Iron and plain toner transfer , myself and MJL (member) seem to get 1-2 mil resolution with no or few pits. The silkscreen is harder , it needs to be white and more durable - thats where the foil/laminator comes in. So for $200-300 , I could become the "factory".
I plan on this ASAP , I'm just a little short of $$. just 2-3 visits to someone elses fab house and I could do it myself with comparable quality.
PS- if I had that stuff , I would do your 6 boards for $60 !!! with at least 95% quality.
OS
Mongrel website , always current and updated :
http://www.fidelityforce.com/ostripper
Old 24th March 2011, 08:27 AM   #12
Tarzan is offline Tarzan  Belgium
Tarzan's Avatar
Hoi OS,
Can you tell us a bit more about your Laminator Ideas?
Maybe a new thread on how to diy.
Cheers
Old 24th March 2011, 01:53 PM   #13
mac1257 is offline mac1257  Australia
Default I've simplified precision headset amplifier, Ro = 32R.
Word-precise, it is true. The cheapest thing and Audio
good quality, possible in an easy way to do it yourself.
Old 24th March 2011, 06:41 PM   #14
CBS240 is offline CBS240  United States
CBS240's Avatar
OS
Wow! That would be a swell set up. With that kind of gig, you could actually make some money to pay for your expensive hobby. I wonder how tricky it would be to make multi-layer PCBs. Those board houses use copper electo-plating as opposed to etching. I suppose you could fill the vias with solder to connect them through the board but buried vias would be tricky. A 4 layer board would be ideal for class D and high speed switching circuits I would think.
All the trouble I've ever been in started out as fun......
Old 24th March 2011, 09:36 PM   #15
Can someone please explain to me: 95% quality!
Will you give your customer the money back for the wasted parts and time (assembly and troubleshooting, 100 or more times the value of the boards)?
Even good board houses screw up. What they do after is what makes them great (or not)!
E
Old 24th March 2011, 09:57 PM   #16
ostripper's Avatar
E
Hopefully the customer would have done his R and D. If what he submitted was accurately reproduced, the assembly and troubleshooting would be his responsibility , as he was responsible for the design initially.
A gerber is a gerber , there can be no error on the physical artwork. The design is another story. Don't submit a design , just completed artwork.
95% quality refers to tinning vs. soldermask ... or no plated through holes. For DIY this is quite sufficient. double sided is also sufficient for DIY. I get away with single sided for most amps. I just sold 2 sets of below (blank , drilled , and perfect) for $30USD a set.
OS
Old 25th March 2011, 03:05 AM   #17
Default The new amplifier design P23W1R
The new amplifier design P23W1R.
Today, with the unit, a new amplifier design P23W1R.
Some people like MOSFET and can afford to experiment and
see what they like to hear.
Old 25th March 2011, 11:45 AM   #18
sakis is offline sakis  Greece
sakis's Avatar
this is probably some kind of joke cause i really wonder what is going to happen in these circuitrs if voltage is not 21.8 but 22.6 and for some also reason R16 that is supposed to be 1.855 R actually is 1.856 R .....
am i missing something ???
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 29th March 2011, 08:14 PM   #19
Default Re: P23W1R
Re:P23W1R
Old 29th March 2011, 08:28 PM   #20
These schemas should be more readable. I will see them better if they will be from app like Eagle.
My First DIY Audio Project: A Custom CMoy Test Board. isen78 Chip Amps 9 9th March 2011 01:58 PM
Need expert help with first DIY car audio 3-way design nola000 Car Audio 13 9th December 2007 02:13 PM
multi channel audio sender control unit (bpm synced patterns) davepenney Digital Source 4 19th January 2007 02:06 PM
pro amplifiers vs. home audio amplifiers bonsai171 Solid State 26 25th February 2004 08:24 PM
Looking for a good quality DIY design...Please help philcav7 Multi-Way 8 19th November 2002 04:51 AM
Copyright ©1999-2013 diyAudio
