I created an audio filter circuit using an Darlington pair emitter follower for signals in the microvolt to millivolt range. The circuit didn't work as intended. At that signal level all I got was complete attenuation. Increasing the input signal to the hundreds of millivolts range the filter gave the expected unity gain response in the band pass. It is not a noise issue, so what is going on?
Simulation using LTSpice 4 didn't show any problem at the microvolt range but obviously something does change down in those regions. Would changing to a CFP configuration improve matters? |
#2 |
More info needed.
I'm wondering why you chose a Darlington, but it'd certainly help if we knew what transistors were used and how you have it biased. |
#3 |
Darlington speech filter circuit
| small-signal (small-power) fast switching complementary transistors | Lola Luna | Solid State | 3 | 8th April 2010 07:51 PM |
| Small-signal (or small power) pentode that can handle 400V (or more)? | GordonW | Tubes / Valves | 12 | 13th June 2008 02:07 AM |
| Help understanding a darlington pair | Buckeye Sound | Solid State | 4 | 28th August 2007 11:56 PM |
| is darlington pair is unsuitable for audio amplifier? | boxedin | Solid State | 29 | 13th October 2006 12:00 AM |
| Darlington pair | Tualek53 | Parts | 9 | 16th August 2005 07:54 AM |
| Page generated in 0.08172 seconds (57.16% PHP - 42.84% MySQL) with 11 queries |
