Old 30th March 2011, 04:31 PM   #51
5th element's Avatar
I use a band saw to chop up my boards.
but still ended up with pin holes and crap. Here the reason was I used an ink jet transparency that clearly wasn't opaque enough.
I use a laser printer for mine and I've never had any real trouble with it. Occasionally it wont put toner down in a tiny area, creating, as you've mentioned a pin hole, but usually there's only one per design and usually this isn't in a critical area.
Back in high school I took the electronics course, and as part of that we had to build a simple project, this included making a PCB. To help with the pin hole issue we put the transparency through the printer twice, thus doubling up the thickness of the ink layer. The printer used here was a laser too.
I have tried doing this myself and it doesn't work, the transparency doesn't align itself well enough to print over the exact same area. With small SMD packages this is completely unacceptable, the spacing I use between 0.5 pitch pins is only 0.228mm, so there's no margin for error.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 11th April 2011, 09:07 PM   #52
destroyer X's Avatar
Default Please, watch this video friends
This demonstrate this simple software use:
YouTube - Livewire and PCB Wizard review
regards,
Carlos
DIY Klipsch Crites-style Crossovers Netdewt Multi-Way 11 13th September 2011 06:25 PM
Board to board soldering: BGA/SMD style NeoY2k Parts 0 7th December 2008 04:36 PM
DIY soldermask for home-etched PCBs DJ Exprice Parts 2 20th May 2006 04:37 PM
Naim style DIY Preamp Agisthos Solid State 4 15th November 2005 07:55 AM
Amplifier made in Brazil, old style, simple and good enough! destroyer X Solid State 4 7th July 2004 01:12 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
