Old 18th March 2011, 09:37 PM   #1
Kwikas is offline Kwikas  Australia
Default Fitting an IR controlled switch for power amps
I have a rack of power amps (pro) in a separate room - i.e. away from my HT room. I want to be able to switch these on/off using my remote from the HT room.
Can I somehow replace the on/off push switches on these amps with an IR type switch? I doubt it's a simple as that and I'm no electronics expert obviously....so what's involved in doing this?
All my other gear in the rack can/is able to be turned on/off by IR switches. Not the power amps however.
Can anyone offer up some advice here? Thanks.
Old 18th March 2011, 09:56 PM   #2
I can think of many ways to go about this.
One is to use a remote x-mas light controller providing that the triac or relay inside the unit can handle the current draw.
If it is a triac it can be easly replaced for a higher current one.
If I had more details I might be able to help you devise something more suiteable to your needs .jer
Old 18th March 2011, 10:43 PM   #3
nigelwright7557's Avatar
You could buy a IR controlled extension lead that would switch off the lot in one go.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 19th March 2011, 04:27 AM   #4
Gerald/Nigel - thanks.
I should have provided more info.....
I've got about 6,500 watts of power through 6 x Q66 EV's (2 are bridged for subs) and 2 x Q44 EV's.
So, no single lead here Nigel I'm afraid.... and that would have been the easiest solution for sure.
2 amps for each 10amp outlet is the best set up and that's what I've got. 1 full phase of a 3 phase circuit has been run to the rack.
So, my quest is to find out how I am going to switch on each amp using IR?
Voltage Controlled Switch CutRock Analog Line Level 9 3rd January 2011 07:15 AM
Timer controlled speaker switch... JRace Everything Else 10 20th July 2007 03:39 PM
remote controlled line level switch brainsalad Solid State 1 18th November 2006 02:34 PM
Aleph30 (and other Class-A amps) Hi-Lo Power Switch? Daveis Pass Labs 12 6th April 2006 04:10 AM
Page generated in 0.07583 seconds (72.22% PHP - 27.78% MySQL) with 10 queries
