Shunt regulator for a phono pre - Page 3 - diyAudio
Old 12th August 2003, 05:59 PM   #21
ALW is offline ALW  United Kingdom
Default Frank
I could add to it by saying that using filmcap for PSU filtering is also not such a good idea although for other reasons.
Would you like to offer a reason why?
Andy.
Old 12th August 2003, 08:27 PM   #22
diyAudio Senior Member
fdegrove's Avatar
Well, I can only try.
The lesser electrolytic caps tend to filter out mainsborne crud, rectifer noise and what have you far more effectively than a filmcap would in a typical CRC filter.
On the same topic, does anyone use capacitance multipliers for their circuits?
While these are limited in use due to max. transistor dissipation, I find them very useful, even in valve PSUs.
Moreover, they don't cost much to cobble up and try out.
Lately, I've been fiddling with one for a tube preamp, using a //ed ECC81 and I'm really smitten with the results.
Frank
Old 12th August 2003, 09:06 PM   #23
Surely isn't the filtering effect totally dependant upon source R and the resultant cap Z?
I see no reason why a film cap should be worse than a 'lytic of the same value.
I'm puzzled...
Andy.
Old 12th August 2003, 09:25 PM   #24
fdegrove's Avatar
Where a filmcap is too good in this application is in DA.
If we'd use regular, off the shelf caps their " poor properties" can be put to good use to help suppress RFI.
I'm not saying they'll do everything you've ever dreamt of but they smooth these critters out better than a filmcap would in that position.
Neither am I saying that you can't use filmcaps in a PSU but if you're going to use regulators anyway, I see no point.
After all, all you need is a clean supply and good PSRR from the reg and whatever sits in front shouldn't leave its sonic fingerprint.
Any opinion on the cap multiplier?
Frank
Tube shunt regulator for phono amp velvetsunrise Tubes / Valves 5 4th May 2008 04:13 PM
Copyright 1999-2017 diyAudio
