My new hybrid amplifier - Page 2 - diyAudio
Old 17th March 2011, 10:05 AM   #11
sajti is offline sajti  Hungary
And finally the PCB over the heatsink.
Sajti
Old 17th March 2011, 10:30 AM   #12
The power transformer is toroidal, 90VCT, 1000VA, wounded on 1500VA iron for low leakage, and low noise.
Sajti
Old 17th March 2011, 11:43 AM   #13
AKSA is offline AKSA  Australia
Beautiful design, Sajti. I see the output buffer is error corrected, wow!
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 17th March 2011, 11:46 AM   #14
Hugh
Hi Hugh
thanks! Unfortunately the quality of the schematic is not quite good, because I have to reduce the size, for another forum. So there is no error correction at the output. The small transistors are working as overcurrent protection.
Sajti
Old 18th March 2011, 06:31 AM   #15
There are some difference between the posted schematic, and the final PCB. So the small signal stage contains 2SC2240/2SA970 instead the KSC1845/KSA992
Sajti
Old 19th March 2011, 07:26 PM   #16
Some more changes: I reduced the value of the feedback resistors to 4x221ohms. I did it, because of the simulation results. The voltage gain is 2, and the distortion falls to 0.0012%, and the 2nd harmonic is 0.001%, the 3rd is 0.00069%.
Sajti
Old 19th March 2011, 07:54 PM   #17
The final schematic.
Sajti
Old 20th March 2011, 01:03 AM   #18
I see now, it's a conventional EF3 output stage, with EF input stage to a complex complementary singleton drive via a current mirror and a cascode to the pre-driver. Fascinating protection system! Not simple at all, I assume very high OLG and very low THD? How does it sound, does it make you tap your feet and bring out a smile?
Hugh
www.aksaonline.com
Old 20th March 2011, 07:55 AM   #19
Hugh
So, the OLG is about 500. It can be higher, but I don't think that it's necessary. The OLG distortion is 0.22%, with 4ohm load, and 300W output. Mainly 3rd harmonic. Interesting that the closed loop distortion contains mainly 2nd harmonic.
The protectione system is my own development, and contains delayed switch ON, overcurrent, overtemperature, low voltage protection. Self reseting, and the amplifier can handle the short circuit for long time.
The circuit based on Marantz PM11, or MA9, but I try to use better passive components.
Not yet listened, I need some more time to build the PSU, and the tube input stage.
Sajti
Old 20th March 2011, 08:13 AM   #20
Make it as linear as possible, then apply minimal feedback? I see around 48dB of loop gain, with very, very low open loop distortion. It should sound very good indeed, and the protection circuits are a tour de force. Congratulations Satji!
Hugh
www.aksaonline.com
Hybrid Amplifier Design Luck Chip Amps 32 3rd March 2009 02:43 AM
The Perfect Hybrid Amplifier Stee Solid State 0 27th July 2008 08:03 PM
Hybrid amplifier.. Please help.. DoomPixie Solid State 96 2nd March 2006 02:54 PM
Hybrid amplifier help... DoomPixie Tubes / Valves 83 20th February 2006 01:28 PM
HYBRID POWER AMPLIFIER - Please Help! gianmaria Solid State 40 20th May 2005 01:46 PM
Copyright ©1999-2017 diyAudio
