Pre out attenuation
I recently resurrected a Teledyne Acoustic Research GCS 80/40. My problem is that it has no gain controls on it. I'm feeding it with a Pioneer AVH-P6500 DVD head unit, 4V preouts. The problem is when I come off of 0 on the volume the gain is so high it starts to hiss, by 20 (max of 62) its screaming (sounds good too I might add). Can anyone suggest a attenuation circuit that might be commonly used in these situations? I don't want to go back in the amp or build a box with a pair of pots.
