#21 | |
OS
Mongrel website , always current and updated : http://www.fidelityforce.com/ostripper |
#22 |
Ah, didn't see that. You are right, OS
Hugh |
#23 |
Actually we are both right, as the efficiency would vary depending on how low or high the rails are. A simple bootstrap amp's bias will dive into class A at the low end of the convertor (+ -20v - for example). Some would confuse this as a class D/AB hybrid , but the amp itself is always somewhere between A and B.
OS
#24 | |
49 - for the 17th time
![]() ![]() ![]() Hello Brother Carlos - It has been too long sense talking with you - I send you good thoughts - and as always wish you the best!!!
DIY audio can be expensive – but getting to see things go up in smoke - that's priceless!!!! ..... "whatever - call it brainfart of Mighty ZM"
#25 |
i felt so sad and depressed that i was eating alike a crazy...trying to kill myself eating.
I know Thomas, i do receive your "energies" and your image and name appear in my mind..... i know that Thomas..very well..and sending you too. Well boys (i am 60 so i can call you this way), don't you think this is a hell complication when we can increase transistors quantity...don't you think this should be a very exagerated solution to save some power transistors? Part's count is huge... another big board, auxiliary to the supply...all that stuff to increase efficiency....... this is too much complication to my old brain. regards, Carlos
Dx Super A - Brazil - Layout Zimmer; http://www.youtube.com/watch?v=yxpYnUA6Bj0 |
#26 |
and enjoy Symphonic from Australia.... i am plugged into youtube.
you should do the same if you can. Speaker crossover is my design and uses 7 bands regards, Carlos
#27 |
#28 |
Too much exageration in my point of view.... better to increase transistors and not to produce all that whale board.
regards, Carlos
#29 |
Banned
Can we see the schematic of the MAKO ?
#30 |
I hope, in the future i will be free to do that.
Was inspired in the Precision I...wich schematic was already attached. regards, Carlos
| Anyone heard about the Lowther Shark ? | lowtherdream | Full Range | 0 | 3rd November 2008 09:38 PM |
| The New Hyper Balanced Amplifier | TimS | Solid State | 6 | 21st April 2008 01:02 AM |
| 311T (211 alike) HIGH power triode | firefart_1st | Tubes / Valves | 8 | 11th June 2006 07:44 PM |
| Shark! HEEEEEEELLLLLLPPP!!! | u | Everything Else | 1 | 24th March 2006 12:49 PM |
