Clone Goldmund Amplifier
Old 4th May 2011, 03:14 PM   #51
tommy1000 is offline tommy1000  Denmark
Originally Posted by jacco vermeulen View Post
You lot forget that the case of the Telos 1000 is the heatsink.
~10,000 square centimeters of surface (aka ~600 sq in.)
The heatsink is not connected to the case. Telos 1000 uses the same teflon spacers as used in the Telos 2500 and the same cut out in the back plate. Hope this helps.
Old 4th May 2011, 04:32 PM   #52
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Fancy teflon washers are not spacers, just part of the mechanical grounding routine.
The heatsink used is a Fischer SK56, a 6" length does ~0.35C/W (uncorrected).
Exterior surface of the heatsink is ~3000 square centimeters, the case has three times as much.
Given the power output of the Telos 1000, think how hot the heatsink would become if it were thermally isolated from the case.
http://img7.imageshack.us/img7/7262/img7x.jpg
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 4th May 2011, 07:05 PM   #53
Yes, the heatsink gets very hot. This is from MM 28. You can see the same solution, the heatsink is isolated from the case.
Old 4th May 2011, 07:07 PM   #54
What do you call the yellow stuff ?
(each of the Allen bolts is a thermal bridge)
Old 4th May 2011, 07:20 PM   #55
It is a copper plate mounted on the heatsink only. Not connected to the case. Same design is used in the Telos but different size.
Old 4th May 2011, 07:57 PM   #56
cfan is offline cfan  United States
You just simply can't use the cabinet as a heatsink. It's not technical but ergonomic and safety issues. Will you paid $$$$ for an amplifier that you can't put hand on it more than 20 seconds?
Old 4th May 2011, 10:09 PM   #57
How many examples would you like me to name ?
Old 5th May 2011, 12:00 AM   #58
I won't surprise that you can name 10 examples of other designs but we are talking about the monster expensive Goldmund. It's different.
Old 5th May 2011, 12:28 AM   #59
In the words of Mr Charles Hansen : GMAFB
Goldmund manufactures analog amps, efficiency rules for Class AB power amps apply for them as much as they do for other brands.
Goldmund can bump up the C/W number of the heatsink a little by using the back of the heatsink base plate as well for natural convection, but it will not be sufficient by a long shot to handle the average dissipation level of such a powerful amp.
Only way to get rid of that much heat is through the case, of which the Telos amps have plenty, both in air exposed surface and lbs, the Telos 1000 has at least 60lbs of aluminum in the panels alone.
Worst case max dissipation of a Class AB power amp can be as high as the nominal power figure in 8 ohm.
If the heatsink of a Telos 1000 would be totally isolated from the case, it could and would get hot enough to melt thermoplastics on it.
Not bragging, elementary thermodynamics for analog audio amplifiers.
(10 easily, even one twice as pricey as the Telos 1000)
Old 5th May 2011, 02:58 AM   #60
tcqanh is offline tcqanh
Originally Posted by oDoh5 View Post
How much dose it cost?
about $1k for all parts. is it worth ?
personally, I believe this is the best souding SS ampli I've heard comparing SS ampli the the market with the price under $4k.
Clone Goldmund AmplifierHide this!Advertise here!
Goldmund Mimesis 3 Clone, World's Best Amplifier!!!! NagysAudio Solid State 128 8th December 2010 07:30 AM
Goldmund lumanauw Solid State 32 26th January 2006 04:08 PM
Proac 2.5 clone, what Amplifier kevinkuang Multi-Way 20 17th March 2005 12:21 AM
Goldmund Speakers audioPT Multi-Way 0 11th September 2002 09:52 AM
Copyright ©1999-2017 diyAudio
